Author Topic: TC Front Anti-Roll Bar specs  (Read 1858 times)
Offline cazman
« on: Sunday,January 30, 2022, 04:47:55 AM »
Does anyone have the dimensions for the front anti-roll bar on a TCS?
I cannot find the diameter, length, arm length, etc anywhere.
1973 Europa TCS
Re: TC Front Anti-Roll Bar specs
« Reply #1 on: Sunday,January 30, 2022, 03:03:06 PM »
I have an S2 and TC bar on the shelf. The overall dimensions are the same except diameter.
S2 .570"
TC .700"
+/- some for paint.
I used this calculator to figure out what the factory rates were before making an adjustable 7/8" one.
http://www.gtsparkplugs.com/Sway-Bar-Calculator.html
What Turboforce did is probably the best way to get a little stiffer and to have it adjustable. Many old Formula Fords did the same.
Offline cazman
« Reply #2 on: Monday,January 31, 2022, 07:04:49 AM »
Thanks.  I show about 180lb spring rate for the front bar.
1973 Europa TCS
« Reply #3 on: Monday,January 31, 2022, 06:46:24 PM »
I wrote down 137 lbs on the TC bar, 180 lbs on the aftermarket .750.  247/323/414 on my 7/8". It's been a while so I don't know what I used for my input on the stock bars.
« Reply #4 on: Tuesday,February 01, 2022, 03:30:15 AM »
I think Serge calculated it on his anti-roll bar video. Seems it was close to your number Clifton.
Offline cazman
« Reply #5 on: Tuesday,February 01, 2022, 05:11:23 PM »
I had to crawl under the nose and take some measurements and I think the 137 lbs is probably right.
1973 Europa TCS
