So, if I understand a few of you, it should flash when pulled toward me ( on low beam), and lights should not go out when pulled. so pulling makes high beam lights go on and does not change that the low beams are on. (in other words no darkness when pulled). time to pull the switch apart, must be a dirty contact after 50 years old. thanks for input guys.
