I had a helper this past weekend and she actually enjoyed it!
She's managed to get most of the filling and sanding done on the body tub, which means I might get to prime the body next Sunday.
I tackled the seatbelt mount plates in the rocker panels, the head of the mounting bolts had to be cut off with the angry grinder as there was nothing holding the nuts on the back side. I had made a pair of replacement plates a few weeks ago, and they fit like a glove.
Next up was replacing the firewall, I spent most of Saturday grinding out the existing fiberglass that held in the beaver board. I then spent the rest of the day cutting up some plywood to fit the tub and glassed both sides with cloth. Monday saw me install the pieces from the cockpit side. The panels will get glassed in on the engine side once I pick up some more resin.
At the end of the day Monday the car looked like this:
If I can convince my helper to help out again next weekend, the car should be all one shade of grey.
Rod
