Author Topic: My Type 54 to sort of 47 Conversion  (Read 132972 times)
Offline RoddyMac
« Reply #30 on: Monday,June 30, 2014, 07:43:40 AM »
Some minor progress this weekend, I managed to find enough time to fabricate the upper and lower front wishbones, front "body mount" plates, plus make up the steering rack mounts.  At the moment the rack mounts are only tacked in place, I was going to set the rack height for bump steer etc, but I'm missing the nuts that hold the upper ball joint to the upright.  So every time I tried to move either corner vertically, the upper BJ would pop out.  In the end, I tacked the mounts at the stock height, or at least at the height provided in the drawings available on line.  I had hoped to take the chassis over to where the body is stored to see if it all fits, though I'm sure it will (fingers crossed).
« Reply #31 on: Monday,June 30, 2014, 08:07:53 AM »
Looks great!  :trophy:
I didn't think about it till now, but I was wondering if you're going to tie the end of the tranny into the frame. I assume you're going to pick up the bell housing with the hoop at the end of your frame. Are you planning on other attachments?
Offline RoddyMac
« Reply #32 on: Monday,June 30, 2014, 08:14:22 AM »
I've been debating on what to do about the tranny mount.  I am going to pick up two bell housing bolts and mount them to the rear hoop.  But, I'm half thinking about making a frame that also attaches to the hoop and would pick up the rear of the tranny, plus support the rear of the body and double up as a jacking point.  I don't think the bell housing bolts will be able to take the load of supporting the gearbox and part of the weight of the engine.  The FT200 in the 47 appears to use 1/2" bolts, where as the bell housing bolts are only 3/8".
« Reply #33 on: Monday,June 30, 2014, 10:37:12 AM »
I don't remember (if I ever knew) how the 47 mounted the tanny to the frame but quite often, the bell housing would have two bosses that take the bolts you mention. Maybe you can make a similar modification to your bell housing. Or you might make a sort of "girdle" that picks up the four (I think) mounting bolts between the block and bell housing. Of course, picking up the back of the tranny would mean you wouldn't have to pick up the front of the tranny. Jensen's D Production Europa only used the standard mount points.
Offline RoddyMac
« Reply #34 on: Monday,June 30, 2014, 10:53:22 AM »
Here are two shots of a 47 replica that a friend took at a show in the UK:
The FT200 has ears off the side plates that mount it, and appear to be quite beefy.
And here's a very rough sketch of what I'm now leaning towards:
Once I get the motor and gearbox as a unit in the chassis (I still have to carve off the alternator mount), I can measure everything and create a drawing to see if it will work.
Offline RoddyMac
« Reply #35 on: Monday,October 13, 2014, 06:58:01 PM »
Its been too long since my last update, so here's what I've been up to....
I had some plate laser cut for the rear uprights.
Made up a jig to locate everything and tack welded the assemblies.  I've going to hopefully have them fully welded this week by a friend with a better welder than I have.
« Reply #36 on: Monday,October 13, 2014, 08:02:39 PM »
Very nice!!! Please post more often! You have a really great project going on!
« Reply #37 on: Monday,October 13, 2014, 10:52:13 PM »
That's very impressive, engineering at it's best. I struggle making simple brackets so watching progress like this is inspiring. Keep 'em coming....
Offline Lotusjps
« Reply #38 on: Tuesday,October 14, 2014, 08:51:49 AM »
... Or you might make a sort of "girdle" that picks up the four (I think) mounting bolts between the block and bell housing...
Essentially that's what I did to mount my NG3.
« Reply #39 on: Tuesday,October 14, 2014, 09:16:05 AM »
Very nicely done!!  :welder:
Offline RoddyMac
« Reply #40 on: Tuesday,October 14, 2014, 09:42:42 AM »
That looks very interesting, I may have to somewhat copy that mount.
Offline Lotusjps
« Reply #41 on: Tuesday,October 14, 2014, 10:20:23 AM »
Here's my drawings if you want.
Offline RoddyMac
« Reply #42 on: Tuesday,October 14, 2014, 10:38:35 AM »
Thanks!  That saves a ton of time.
Rod
Offline Lotusjps
« Reply #43 on: Tuesday,October 14, 2014, 10:54:34 AM »
Just realized the drawing doesn't show that I used DOM tubing in between the larger holes and then pressed poly bushings into them to suspend it from.  I had the pieces laser cut then powder coated after welding all together.
Offline Mecky
    • Lotus Europa Racing
« Reply #44 on: Wednesday,October 15, 2014, 12:02:22 PM »
Wow, I love the self-made hub carriers  :pirate: :coolpic:
