Author Topic: GEAR BOX TYPES  (Read 940 times)
Re: GEAR BOX TYPES
« Reply #15 on: Tuesday,January 04, 2022, 01:43:31 PM »
The dirty one definitely looks like the 365 fitted to my 73 Special, and I'm pretty sure that the difference between the 352 4 speed and 365 5 speed gear linkage is just the rear section from the bell housing to the selector shaft on the back of the gearbox. I believe the selector shaft diameter also comes in two different diameters, though dont know if this is just on the 365.
Offline kram350kram
Re: GEAR BOX TYPES
« Reply #16 on: Tuesday,January 04, 2022, 02:48:04 PM »
So a 365 is a 5 speed?
Re: GEAR BOX TYPES
« Reply #17 on: Tuesday,January 04, 2022, 02:58:49 PM »
Yes I'm pretty sure the 365 was the only standard (From factory) 5 speed used on the Lotus Europa Twin Cam engined cars that had that option selected. I'm guessing that is probably most of the Specials.
Re: GEAR BOX TYPES
« Reply #18 on: Tuesday,January 04, 2022, 09:23:24 PM »
There are a number of different 365 transaxles out there: the Lotus modified one, Renault rear shift and Renault side shift.
