Author Topic: How do I remove bonded screen  (Read 876 times)
Offline Sparkrite
« on: Wednesday,December 08, 2021, 03:27:00 AM »
I have just collected a new screen direct from Pilkington and cant work out the best way to remove my old screen, specifically without damaging the original trim which I would like to re use. I could not find the proceedure in the old  threads so would appreciate any help. The current sealant/adhesive is very sticky and tough,not solid but slightly malleable, so the only way I can envisage it working is if I gouge out the sealant between the glass and the body from inside of the car.
Re: How do I remove bonded screen
« Reply #1 on: Wednesday,December 08, 2021, 03:52:03 AM »
There are a few ways to remove the bonded glass. A sharp but flexible fillet knife is what I used. Another clean and effective method would be a wire cutting system. Leave the trim attached and soften the bond with a heat gun. Make a small hole starting point and insert the wire. Carefully work your way around the glass, take your time...
https://www.harborfreight.com/professional-windshield-removal-kit-96339.html?utm_source=google&utm_medium=cpc&utm_campaign=12144811130&campaignid=12144811130&utm_content=117789314798&adsetid=117789314798&product=96339&store=151&gclid=Cj0KCQiAzMGNBhCyARIsANpUkzOQoqVVEyNbr_48aPuAht-oeGVYGya-d7cNKfdKBqh4CGhBbT6AOTkaAnwzEALw_wcB
« Reply #2 on: Wednesday,December 08, 2021, 03:52:33 AM »
Windscreen fitters use a flexible blade, not sharp enough to cut the user, but thin and bendable enough to make the cut through the mastic.
Once the top section is cut, the windscreen usually comes away easily. So far I have removed 5 without any dramas.
The plastic surround is just a push fit over the edge of the windscreen, and should come away easily before you cut the mastic joint.
Offline Sparkrite
« Reply #3 on: Wednesday,December 08, 2021, 04:28:23 AM »
My trim is firmly stuck so I cant get the wire method through. So it seems I will have to proceed as I first imagined and work at the top and sides then try and push it out. Added to all this I will have to remove this new screen yet again when I come to repaint the car some time in the future.
« Reply #4 on: Wednesday,December 08, 2021, 04:44:16 AM »
If you are repainting in the same colour, removing the screen is not necessary. They can use masking tape on the trim. I have had 1 done this way, black only.
Online Kendo
« Reply #5 on: Wednesday,December 08, 2021, 03:21:23 PM »
I recently used that Harbor Freight kit to remove my windscreen. If you can get the wire through without using that long T-blade tool, do it. If you have to use the tool, 1) file round the tip so it doesn't gouge the paint, 2) push the tool through along a 3-4 inch section, so 3) you don't crack the windshield like I did. If you use that tool to push the wire through, you end up with the thickness of the tool tip plus two wire diameters. That was enough to crack the windshield at the insertion point. After that, it all went remarkably smoothly.
Offline bert knip
« Reply #6 on: Wednesday,December 08, 2021, 05:17:39 PM »
How, where did you get your windscreen?
I am looking for one, but Pilkington says they do not hqve them?
Bert
« Reply #7 on: Wednesday,December 08, 2021, 06:09:00 PM »
   I used a local window installer to cut out my el Camino windshield. They wrapped a wire around the window with a set of crank handles that tightened the wire as it cut thru the sealant in less than 5 minutes.
Offline Sparkrite
« Reply #8 on: Thursday,December 09, 2021, 05:30:30 AM »
Bert
I got it from Pilkington automotive ltd in Heathrow. I understand it comes from the Netherlands to their main branch in Redditch UK, then onto Heathrow.
Offline Sparkrite
« Reply #9 on: Thursday,December 09, 2021, 06:20:17 AM »
I should have added that Pilkington gave me the details of a trade fitter who placed the order, and once I paid them I simply  collected from Pilkington.
Offline bert knip
« Reply #10 on: Thursday,December 09, 2021, 10:02:03 AM »
That would worth to investigate , because I live in the Netherlands, and I am thinking of shipping the car next april.
« Reply #11 on: Thursday,December 09, 2021, 02:58:02 PM »
    Bert,
  There is alot of what if's here , but if your car is in Florida , and registered and insured you may be entitled to a free replacement of your windscreen.
  Windshield Replacement Laws In Florida
October 28, 2020 by windshield
Contents
Fee florida law
’ve spotted
Insurance. find florida windshield replacement
Insurance coverage options
Having a cracked windshield makes it harder to see the road and is also a safety hazard. If the crack is too large to repair, you may need to remove the damaged windshield and install a new one. Follow these steps for front windshield replacement.
Apr 25, 2019  · “Thousands of Floridians have unknowingly become the subject of litigation over their windshield replacement claims without their knowledge or consent. This practice must stop. Florida law holds…
An AOB gives the contractor the authority to file a claim, make repair decisions and collect … Importantly, the new Florida law also truncates a contractor’s ability to collect attorney …
It’s the Wild West out there, nowhere more so than in the Sunshine State, where Central Florida’s WESH 2 news reports that a man fired several shots through his own windshield after he says the …
If your windshield is too damaged you may have to replace it completely, which can cost a few hundred dollars. In Florida car insurance companies must cover the costs of windshield repair by law (FL Statutes, Sec. 627.7288). If you have bare minimum auto insurance then you will have to pay for repairs or replacement yourself.
Action 9 investigates companies that offer to replace your “dinged” auto windshield for “free.” Anthony Nunnelly says a …
Replacement Windshield For 2016 G3 Angler V164 New Montauk-T-Topless-2™ (MT2™) is shipping in 3-5 business days! … Shade Kit; G3® Angler V164 C, O/B (2013 – 2016): Styled To fit™ boat cover, Bimini- Top/Boot, Shade Kit; G3® Angler V164 … Styled To Fit™ Boat Cover, Bimini-Top/ Boot, Shade Kit; G3® PB 20 C Catcher Top Laid Down Windshield OFF, O/B ( 2005 …
If you’re a Florida resident, thoroughly understanding the state’s Driving Under the Influence, or DUI, laws are very important. Here are the things you need to know about the Florida DUI laws.
It seems simple: a legal spat over how much it costs to fix a broken windshield … is a "one-way" attorney fee florida law allows. Under state law, the losing party must pay the winning party’s …
In the state of Florida, windshield cracks and chips are repaired free of charge. According to Florida statute 627.7288, if you have comprehensive coverage on your vehicle your insurance company will pick up the tab for any repair or replacement that you may need. The law states that your deductible will be waived.
Jun 25, 2020  · In florida car insurance companies must cover the costs of windshield repair by law (FL Statutes, Sec. 627.7288). If you have bare minimum auto insurance then … According to Florida statute 316.2952, there are things you must know about … will send someone to your home or office to replace or repair your windshield.
Windshield Replacement, Las Cruces Nm Windshield Replacements for 2015 Volvo S60 4 Door Sedan were the most expensive type of auto glass repair overall in Las Cruces, New Mexico,, which typically costed an average of … Windshield Repair in Las Cruces, NM. Randy leads an experienced team at Las Cruces, personally having over 25 years of industry experience. His trained
A small crack in the windshield can easily become a major problem for you if you run over a bump in the road or if the windshield is damaged further. Small cracks and chips can be easy to miss, but once you’ve spotted one, it’s important to take your vehicle to a specialist. The good news is that if
Car Insurance Windshield Replacement Replacing Windshield Wipers Will Geico Replace A Scratched Windshield Is There A Size Difference In Stock Windshields And Replacements Windshield wipers are vehicle specific, so it’s important to know the proper size before purchasing new wipers for your vehicle. Simple measuring or researching online will ensure you have the correct size wipers for your car.
Brown, 45, who has made only vague references in the past to troubles with the law, was convicted twice … her car after kicking or punching the windshield and shattering it, according to a …
Jun 12, 2020  · In Florida, it’s only illegal to drive with windshield damage if it obstructs the view of the driver. Ask your provider about $0 deductible options for FL cracked windshield insurance. find florida windshield replacement car insurance coverage options and then compare quotes!
Windshield Replacement In Sandy, Utah Replacing Windshield Wipers Will Geico Replace A Scratched Windshield Is There A Size Difference In Stock Windshields And Replacements Windshield wipers are vehicle specific, so it’s important to know the proper size before purchasing new wipers for your vehicle. Simple measuring or researching online will ensure you have the correct size wipers for your car.
May 18, 2016  · While Florida does allow window tint, it must comply with the following: Tint on the windshield must be non-reflective, and can only be in the area above the AS-1 line provided by the manufacturer. No reflective or mirrored tint is permitted on the windshield.
Always verify Before Hurricane Irma even hit Florida … auto windshield replacement technicians. If it sounds fishy, it probably is, the NICB says. Report suspicious activity to local law …
Windshield Replacement Alamosa Co Replacing Windshield Wipers Will Geico Replace A Scratched Windshield Is There A Size Difference In Stock Windshields And Replacements Windshield wipers are vehicle specific, so it’s important to know the proper size before purchasing new wipers for your vehicle. Simple measuring or researching online will ensure you have the correct size wipers for your car.
   alot of IF'S,  and
   just  my 2 cents,
    Dave K
