Author Topic: REBUILDING YOUR RENAULT DISTRIBUTER  (Read 926 times)
Offline 1970S2
    • LOTUS EUROPA COMMUNITY
« on: Tuesday,December 07, 2021, 09:05:46 PM »
Having trouble with erratic idle , poor acceleration , stumbles.......chances are your bushing in the distributer are wore out on the mechanical advance, no parts are available, I made my new bushings out of bearing bronze, these will last , it's not a job for the average mechanic, you will need a lathe and machining skills to rebuild this, the advance weight bushings are made from fiberglass based material that wears out quickly, the upper part of the weight has a cam follower that rides in a slot, mine was hanging out of the slot, after sizing , machining and installing them, we are back on track,
« Last Edit: Tuesday,December 07, 2021, 09:13:15 PM by 1970S2 »
Online dakazman
Re: REBUILDING YOUR RENAULT DISTRIBUTER
« Reply #1 on: Tuesday,December 14, 2021, 04:02:34 PM »
  I found some additional info here:
    http://www.lotuseuropa.org/LotusForum/index.php?topic=2058.msg31934#msg31934
