Author Topic: grease zerks on driveshaft joints.....  (Read 1292 times)
Offline rascott
« on: Saturday,November 06, 2021, 11:05:17 AM »
on my '69 s2-
i have been unsuccessful at greasing the u-joints on the drive axles.
i can't get my grease guns to fit onto the zerks- not enough room to get the nozzle on 'em.
any tip to make this happen?
all the grease gun fittings i'm finding look just like what i have.
Re: grease zerks on driveshaft joints.....
« Reply #1 on: Saturday,November 06, 2021, 11:21:26 AM »
There are longer zerk fittings available which allow the gun to attach to.
Offline rascott
« Reply #2 on: Saturday,November 06, 2021, 01:27:10 PM »
thanks for that.
it seems the route i will take.
what first looked like an easy service has become more involved.
just tried removing the zerk and using a rubber tipped adapter on the grease gun.
last time this was done was probably 20+ years ago(last reg. mabe 1985), and the "grease" in the joints may be cake- i see no sign of oozing......
i may have to learn how to service those u-joints.
how hard could that be? haha
Offline SwiftDB4
« Reply #3 on: Saturday,November 06, 2021, 04:31:15 PM »
If you're only trying to get the car moving short term OK.
Otherwise I would change all the u joints over 20 years old.
Grease condition questionable.
« Reply #4 on: Saturday,November 06, 2021, 05:36:27 PM »
For now, use a needle grease adapter:
https://www.amazon.ca/Performance-Tool-W54216-Grease-Adapter/dp/B000N321UQ
When you next change the u-joints use SKF joints as there small ones has the nipple in the center of one of the caps.
« Reply #5 on: Sunday,November 07, 2021, 07:16:45 AM »
Another difference in the language between the two sides of the pond.
In the UK they are known as grease nipples.
« Reply #6 on: Sunday,November 07, 2021, 07:32:54 AM »
They call them grease nipples over here as well.
Online dakazman
« Reply #7 on: Sunday,November 07, 2021, 07:38:27 AM »
   I have several different adapters for all different angles .  Aircraft vendors have them.
« Reply #8 on: Sunday,November 07, 2021, 07:47:52 AM »
Zerk = nipple
Trunk = boot
Hood = bonnet
Fender = bumper
Gas = petrol
Tire = tyre
Bushing = bush
Stick shift = gear lever
Wrench = spanner
Flashlight = torch
Headers = exhaust manifold
Muffler = silencer
Rotor = disc
E brake = hand brake
Any more differences between the two sides?
« Last Edit: Sunday,November 07, 2021, 07:51:32 AM by 4129R »
« Reply #9 on: Sunday,November 07, 2021, 08:00:48 AM »
Zerk = nipple
Trunk = boot
Hood = bonnet
Fender = bumper
Gas = petrol
Tire = tyre
Bushing = bush
Wrench = spanner
Flashlight = torch
Muffler = silencer
Rotor = disc
World Series = North America 😁
Online dakazman
« Reply #10 on: Sunday,November 07, 2021, 08:23:56 AM »
 Football?
 Soccer?
« Reply #11 on: Sunday,November 07, 2021, 08:42:29 AM »
I was trying to stick to car related differences. There would be a whole dictionary of all the words.
« Reply #12 on: Sunday,November 07, 2021, 09:17:58 AM »
Hot = Live (wiring)
Online dakazman
« Reply #13 on: Sunday,November 07, 2021, 10:26:30 AM »
  Ground = Earth
Offline rascott
« Reply #14 on: Sunday,November 07, 2021, 10:20:08 PM »
i appreciate the responses, have flailed at it a bit more and visited my local parts stores.
haven't found any longer grease nipples yet, but will include the local airport on my next run.
i suspect these are original joints, so replacement may be the best solution.
those skf joints sound like the way to go....
thnx
