September 3, 2024 Forum membership reaches 1,600 !!This Community became 12 years old in April 2024.
I'd drop them a line for more details specs.https://www.johnbrownwheels.com/accessories/wheel-studs
I fitted 12mm studs when I moved to 15" wheels, but still ran 13" wheels with the larger studs for some time. I know the lighter studs work fine with standard Lotus steel wheels and alloys, but there's got to be a reason that most modern cars have moved to using larger studs.http://www.lotuseuropa.org/LotusForum/index.php?topic=219.msg1314#msg1314At the time I never even considered the pattern of the hub end, it's going into a plain hole so as long as the diameter is is a press fit, it's going to work ?Brian
Sorry but those studs don't have the correct knurl. This is as close as I can find:https://rimmerbros.com/Item--i-21H5774XL in 48mm length.As I said 7/16" studs are stronger and easier to get longer ones so might be a saolution.
Demon Tweeks U.K. has 50 and 60 mm long 3/8"https://www.demon-tweeks.com/us/grayston-wheel-stud-243674/You might also consider going to 7/16" studs and lugnuts while you're at it.
