Author Topic: Alternator Wiring Problem  (Read 979 times)
Re: Alternator Wiring Problem
« Reply #15 on: Thursday,October 28, 2021, 07:36:57 AM »
Or a slight modification to the luggage box!  :)
« Reply #16 on: Thursday,October 28, 2021, 12:10:53 PM »
All the usual British suppliers carry the connectors.
« Reply #17 on: Thursday,October 28, 2021, 01:33:29 PM »
     JB,  Do they have the power window connector?  I know you don't have power windows in a S1.
« Reply #18 on: Thursday,October 28, 2021, 03:19:22 PM »
Do you have a photo of the power window connector?
« Reply #19 on: Thursday,October 28, 2021, 04:34:20 PM »
If you mean on the motor it's just two standard insulated spade female connectors on my TC.
« Reply #20 on: Thursday,October 28, 2021, 07:30:30 PM »
  No pics JB , I just had two separate spade terminals on the harness.
 Silver, correct but a connector would be better than standing on your head.
« Reply #21 on: Thursday,October 28, 2021, 07:39:51 PM »
I have some S2 doors lying around.  I'll have a look.
Online GavinT
« Reply #22 on: Thursday,October 28, 2021, 09:07:37 PM »
This look right, D'man?
The window motors are of GM origin.
From a quick search, here's the first hit but there may be better options/prices/locations.
https://jcaparts.com/products/1955-1976-gm-power-window-motor-wiring-harness-connector-pigtail
« Reply #23 on: Thursday,October 28, 2021, 09:45:36 PM »
Thanks for that, the connection is right up against the luggage box so a close right angle connector is needed.
When I fitted a 17ACR unit I had to use one of those connectors as well. The 17ACR does fit but it was probably somewhere around 1/8" clearance on my car.  The 16ACR unit is fractionally smaller but I ended up with a modern (ish) A127 unit which gives more power and bags of clearance.
There's some notes on initially fitting the 17ACR & subsequent A127 on another thread;  http://www.lotuseuropa.org/LotusForum/index.php?topic=4553.msg49433#msg49433
« Reply #24 on: Friday,October 29, 2021, 06:44:28 AM »
Yes.
You can get a connector kit:
https://www.autoelectricsupplies.co.uk/product/47
Make sure any connectors are properly attached.  Insulated crimp connectors like the middle yellow one are notorious for developing poor contact over time.
Ordered yesterday, delivered today. That is what I call good customer service. It is a very good tight fit against the alternator, so should clear the rear luggage box.
« Last Edit: Friday,October 29, 2021, 08:49:57 AM by 4129R »
