Author Topic: A complete Index of Member "Certified Lotus" restoration of his Europa  (Read 11393 times)
« on: Monday,October 25, 2021, 02:17:43 PM »
I don't know why this occurred to me but I thought it might be helpful to those who are doing restorations to be able see how someone else did it. Our own Certified Lotus (I hope he still checks in on us from time to time) documented his restoration pretty completely. Also, he kept his car relatively stock so I thought his thread made a good one to index.
So here's how it works. I went through his restoration thread and found the places where he describes what he's doing. That was pretty easy because he starts with a description and then posts several pictures. I tried to categorize the area of the car he was working on and put a link to that post where I thought it belonged. I didn't keep to the manual categories but rather made them up as I went along so keep that in mind. Also, he would sometimes work on several areas at a time in which case I would dupe the link in the places that I thought appropriate. I didn't take time to read each of his posts so it's probably likely that I missed something but I think it good for a first shot. Because there were sometimes posts from others related to Certified's posts, it would behoove someone using this index to continue reading posts for more information. I focused on Certified's posts since it was his build but that's not to say there weren't good suggestions that Certified decided not to use or insights that could be useful.
It was an interesting experience doing this because it brought back memories and reminded me of some things that are worthwhile. And it made me envious all over again for how clean his car was!
Here it is. I welcome any suggestions on how this can be improved.
Index of Certified Lotus' Restoration of 2358R
Disassembly
Rear Suspension
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg15554#msg15554
Tip
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg17056#msg17056
Shift Linkage
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg17092#msg17092
Doors
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg19083#msg19083
Transaxle
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg20187#msg20187
Parts
Front Suspension
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg16201#msg16201
Shocks and Springs
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg21953#msg21953
Assembly
Engine
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg16512#msg16512
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg23315#msg23315
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31769#msg31769
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32112#msg32112
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32634#msg32634
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32795#msg32795
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32922#msg32922
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg33179#msg33179
Throttle Linkage
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32498#msg32498
Assembly
Front Suspension
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg21939#msg21939
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg22377#msg22377
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg33062#msg33062
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg33124#msg33124
Steering Rack
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg22591#msg22591
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg22894#msg22894
Rear Suspension
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg22928#msg22928
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg23064#msg23064
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg23432#msg23432
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg23490#msg23490
Frame
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg23204#msg23204
Transaxle
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg21940#msg21940
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg22243#msg22243
Shift Linkage
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31565#msg31565
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31734#msg31734
Rear Brakes
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg23793#msg23793
Brake plumbing
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg24257#msg24257
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg24418#msg24418
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg24524#msg24524
Master Cylinder
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg24374#msg24374
Lights & Body
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg30572#msg30572
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg30670#msg30670
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32581#msg32581
Doors
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32548#msg32548
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32664#msg32664
Glass
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg30854#msg30854
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31410#msg31410
Windshield Wipers
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31038#msg31038
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31313#msg31313
Fan
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31415#msg31415
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31665#msg31665
Interior
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31705#msg31705
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31800#msg31800
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31923#msg31923
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31938#msg31938
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32233#msg32233
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32275#msg32275
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32331#msg32331
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32522#msg32522
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32840#msg32840
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32895#msg32895
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32982#msg32982
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg33034#msg33034
Front
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32357#msg32357
Electrical
Engine Compartment
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg31894#msg31894
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32164#msg32164
Fuel Tanks
Trunk
Exhaust
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32086#msg32086
Intake
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32088#msg32088
Fuel Pump
Handbrake
Windshield
http://www.lotuseuropa.org/LotusForum/index.php?topic=1704.msg32438#msg32438
« Last Edit: Friday,November 17, 2023, 02:03:31 PM by LotusJoe »
Offline Exlimey
Re: Index of Certified Lotus' restoration
« Reply #1 on: Monday,October 25, 2021, 06:43:25 PM »
Good job BDA,I have spent a fair amount of time trying to ‘refund’ info on Certifieds resto.
« Reply #2 on: Monday,October 25, 2021, 07:40:35 PM »
I hope this helps, Exlimey. I think it would be great if those who document their restorations would post an index of their restoration thread. Turbo? Chuck? D’man?
« Reply #3 on: Tuesday,October 26, 2021, 03:32:00 AM »
Sounds like a helpful idea! Will try to do so when I am further along...
« Reply #4 on: Tuesday,October 26, 2021, 06:54:26 AM »
I don’t want to slow your progress on your build but I hope you’ll consider starting now, Turbo. You would probably be able to do a much better job and your describing some of the problems of initial disassembly could be helpful to a lot of people since they are probably pretty common.
« Reply #5 on: Tuesday,October 26, 2021, 04:33:15 PM »
Outstanding work BDA! This forum is an outstanding resource for us newbies, and you efforts organizing Glen’s posts really puts knowledge at our fingertips! Bravo!
PS - Glen was an excellent “doctor” but just like healthcare, one should always search the site for a second opinion for any major Europa “ailment”.
« Reply #6 on: Tuesday,October 26, 2021, 04:51:26 PM »
Thanks for the kind words, Surf.
I agree that second opinions are important. I think Glen (Certified Lotus) did a great job with his restoration but there were things I would have done differently - just as as I am sure, there are plenty of things I did that he would have done differently.
« Reply #7 on: Friday,October 29, 2021, 03:59:05 PM »
BDA, can’t tell you how honored I am that you did this. Wow! I know it was a major effort to organize.
I do check in a couple of times a week to catch up on everyone’s projects and see the progress. But I’m staying in the background and enjoying my “arm chair” reading.
I’m now in my 3rd month of living in the mountains of GA and to be honest am perfectly happy trading my sports car life for lake life and boating. It was a bit of a transition to go from owning three (3) classic Lotus cars to none, but I’ve adjusted fairly well (in my previous life I was an ocean sailor).
I’m also very honored that there are over 106,000 views of my restoration post. I never imagined.
Great group here! A lifetime of memories. Thank you!
« Reply #8 on: Friday,October 29, 2021, 05:01:42 PM »
It looks like retirement is agreeing with you! You certainly picked a good place for it!
I've never been much for boats - but if I had taken the opportunity to buy land on Lake Lanier many years ago, I might have taken it up (I still kick myself for not buying land there!).
I'm glad you check in with us from time to time - even if you are a little light on Loti!  :)
I hope you and your BA continue to enjoy your retirement!
Offline Dilkris
« Reply #9 on: Saturday,October 30, 2021, 10:28:57 AM »
A credit to you BDA for putting this together - this represents a gargantuan amount of keyboard work which is very much appreciated. Well done!!!  :trophy:
« Reply #10 on: Saturday,October 30, 2021, 03:41:15 PM »
Your welcome! I hope you find it useful!
« Reply #11 on: Monday,November 15, 2021, 11:56:39 AM »
 :trophy:
  BDA,
  That is quite a comprehensive list , I salute you.  Members helping members is why I believe we come here. Now if we can get Certified to ask Lotus Joe to insert it into the front of his thread.
  To copy and paste it to the back would just not be right.
