Author Topic: original fuse box issues  (Read 600 times)
Offline califkid_66
« on: Wednesday,October 13, 2021, 03:06:11 PM »
i bought an original fuse box cause the other one was falling apart
now sometimes the power goes through sometimes it doesn’t
the bottom fuse i notice right away cause the gauges stop working
the one that bothers me is the top one for the fan i tried cleaning them even scratching them with sandpaper the contact is not regular is there a solution to this or should i just install another type of fuse box i would like to keep the same terminas on the wires if possible
Re: original fuse box issues
« Reply #1 on: Wednesday,October 13, 2021, 04:24:45 PM »
The later, riveted ones get very dodgy as they age and corrode.  Those ones though usually are ok as long as the spring tabs don't fatigue.  Make sure the spring tabs are gripping tightly.  What fuses are you using?
Offline califkid_66
« Reply #2 on: Wednesday,October 13, 2021, 05:29:04 PM »
they are tight but the power doesn’t always go through
and for fuses the manuel say 35 but i read the article  about the difference between british and american fuses i have 20 amp should be 17
« Reply #3 on: Wednesday,October 13, 2021, 08:42:20 PM »
The Lucas fuses are shorter and will better fit the tabs.  Still, it should work the way it is.  When it next doesn't conduct, don't wiggle anything.  Check it with a test light see where it "stops" so you can narrow down where the issue is.
Offline califkid_66
« Reply #4 on: Wednesday,October 13, 2021, 09:26:28 PM »
ok ill try that could be the cheap fuse im going to test the fuses thanks again
Offline califkid_66
« Reply #5 on: Thursday,October 14, 2021, 07:25:10 AM »
it wasn’t the fuse box but rather intermittent fuse it looked ok visually but then tested with multimeter
noticed the end was loose and you can see in the picture it was touching on an off
« Reply #6 on: Thursday,October 14, 2021, 08:17:51 AM »
Just a reminder: I don't know whether they use the British fuse rating system in Canada but be sure to replace your fuses with the proper British fuse rating. See the attached document.
Offline califkid_66
« Reply #7 on: Thursday,October 14, 2021, 08:49:39 AM »
 thanks for the link BDA i had my share of electrical problems so i read as much as i could on the forum i did see the different ratings between british an american but it’s a good idea to mention it once in a while could prevent electrical problem in the future
« Reply #8 on: Thursday,October 14, 2021, 09:41:40 AM »
Well, this is even more important to remind people of than finishing all the surfaces of a wood dash!  ;D
Offline MRN I J
    • Four Ashes Garage
« Reply #9 on: Thursday,October 14, 2021, 10:01:27 AM »
Old British cars are very much underfused, needs a larger fusebox or more fuse boxes to be safe
Regards Chris
other cars inc wifes cars
Offline califkid_66
« Reply #10 on: Thursday,October 14, 2021, 03:52:51 PM »
found some fuses 20 amps shorter than the ones i had works great so the issue was bad quality fuses
« Reply #11 on: Thursday,October 14, 2021, 04:15:39 PM »
Glad it's sorted.  On to the next issue!
