Author Topic: mechanical fuel pump  (Read 402 times)
Offline califkid_66
« on: Wednesday,October 13, 2021, 11:43:17 AM »
i went for a ride and the lotus just decided to stop i noticed i had no fuel in the filter unhooked the fuel line cranked the engine nothing no fuel
my first thought was the membrane is torn
but that wasn’t it it was a one way valve that didn’t close so i took it all apart
cleaned it up tested and now it’s ok must have been some dirt preventing it to close
there is a filter inside the pump in the shop manual there no inline filter before the pump mine is just before the carburetor the one way valve is in the last picture
i cleaned it with carburetor cleaner after i put it in hot water with dishwashing liquids move the valve open closed rinsed it and now they work fine so if your pump stops working just take it apart it could be an easy  fix
Re: mechanical fuel pump
« Reply #1 on: Wednesday,October 13, 2021, 12:18:54 PM »
Nice job!
Offline califkid_66
« Reply #2 on: Wednesday,October 13, 2021, 01:40:22 PM »
thanks!
was easier than i thought  work great except i still did order another one actually two
one electric and one mechanical just in case
« Reply #3 on: Wednesday,October 13, 2021, 02:48:19 PM »
Pump overhaul kits show up from time to time.  They include a new diaphragm and one valves.
Offline califkid_66
« Reply #4 on: Wednesday,October 13, 2021, 02:55:02 PM »
i could not find a rebuild kit but if one shows up ill grab it
« Last Edit: Wednesday,October 13, 2021, 03:11:10 PM by califkid_66 »
« Reply #5 on: Wednesday,October 13, 2021, 04:21:00 PM »
TC engine?
Offline califkid_66
« Reply #6 on: Wednesday,October 13, 2021, 05:22:20 PM »
renault engine 821 wedge was looking local wanted it quickly
last part i bought shipping took 14 days
« Last Edit: Wednesday,October 13, 2021, 05:32:26 PM by califkid_66 »
« Reply #7 on: Wednesday,October 13, 2021, 08:39:45 PM »
Watch ebay as they do show up occasionally.  You can buy new ones here:
https://www.renault16shop.com/alimentation-carburant-
