Author Topic: 4 Reverse gears and 1 Forward (S2, 336 Trans)  (Read 1241 times)
Offline bozman
  • It's a Europa with an "e" at the end.
« on: Friday,October 01, 2021, 10:29:52 AM »
I am near the end of my restoration and I sent the transaxle to be rebuilt.  We replaced the synchro(s) and the synchro hub, along with other minor bits in the transaxle.
After installation we are finding that the gearing is backwards . . . 4 reverse and 1 forwards.  Any insight into what part was put in backwards to cause this to happen?
Thanks in advance.
Greg
Re: 4 Reverse gears and 1 Forward (S2, 336 Trans)
« Reply #1 on: Friday,October 01, 2021, 10:40:03 AM »
Hmm, either you fit a R16 transaxle or they some how jammed in the ring gear on the wrong side.  This is normally impossible as the mesh will be off due to the slight hypoid design.  If they had done a contact pattern they would have seen the problem.
It will have to come out and be stripped again to sort.
Is it the original transaxle?  Or?
« Reply #2 on: Friday,October 01, 2021, 10:48:00 AM »
The 336 gearbox on my parts S2 has a type 336-56 name plate. I'm assuming the gearbox was operating normally before the rebuild?
Offline bozman
« Reply #3 on: Friday,October 01, 2021, 10:49:44 AM »
It is the original gearbox, and it worked as advertised before they took it for the rebuild.  It has the 336-46 plate.
Offline bozman
« Reply #4 on: Friday,October 01, 2021, 10:54:59 AM »
I have read that the crown wheel was "relocated" from the original Renault R16 position to reverse the gearing to suit it for the mid-engine (thus reversed) orientation of the Europa.  Does that mean all the parts are the same, just in a different location/orientation?
Offline Exlimey
« Reply #5 on: Friday,October 01, 2021, 10:59:24 AM »
Hi Greg,that 336-56 box I ‘gave’ you is good for S2 and S2 Fed,time to flush it and try it!Bruce.
Offline bozman
« Reply #6 on: Friday,October 01, 2021, 11:01:43 AM »
Hey Bruce,  we are using the spare as a reference currently.  With all the new parts and work into the original transaxle I really want to use it!
Offline Exlimey
« Reply #7 on: Friday,October 01, 2021, 11:21:06 AM »
Good luck, I am expecting to see it on the 10th at C&C.
Offline bozman
« Reply #8 on: Friday,October 01, 2021, 01:15:23 PM »
From what I can assume (until we have the transmission opened up) I think the crown wheel was installed on the wrong side.  There seems to be a timeframe early in the 336 days (when used in an S1) where the crown wheel was on the opposite side.  I think because mine is a 336-46, it is most likely supposed to be in the driver side, but it was re-installed incorrectly on the passenger side, or vice-versa.  We shall see . . . .
You can see in the attached parts diagrams, one from the S1 parts diagram, and the other from the S1/S2 parts diagram that they are shown on opposite sides.  Perhaps, since mine is a very early S2, Type 54 it has the earlier transaxle in it . . .
« Reply #9 on: Friday,October 01, 2021, 01:24:47 PM »
All the Lotus-bound 336 transaxles received ring and pinion gears specifically made for the application.  The “teeth” drove the other way and the ratio was 3.56 (not used in any Renault).  With the arrival of the R17, they could use the standard Renault gears (3.78 ratio).  The ratio change was why they had to use a custom 5th gear in the Lotus 365.  Otherwise the 5 speed cars would have had a lower top speed than the 4 speed cars.
Long way of saying, no, they didn’t just flip the ring gear.  I’m surprised that they would be able to flip it and not notice.  The gears would not mesh well at all.  Be hard to miss.  Any chance at all they somehow fit R16 parts?
« Reply #10 on: Friday,October 01, 2021, 01:31:59 PM »
The part numbers are the same.  Early Europa printed material used R16 illustrations and were not always accurate.
Offline bozman
« Reply #11 on: Monday,October 04, 2021, 05:48:58 AM »
I did purchase replacement parts for the original 336 trans from R16 shop, which are surely not "Lotus specific".
That said, the only transmission parts we bought from them were the synchro hub, synchro rings, bearings and seals.  I can't think of anything that was replaced that is "rotation direction" specific.
But when I see images of (what appears to be) the same 336 case with the ring gear either the driver side and passenger side, it leads me to believe that they can be easily swapped.  It may not mesh as well, but it seems like the only reason the rotation of the gears has reversed during the rebuild in my case.
« Last Edit: Monday,October 04, 2021, 06:06:45 AM by bozman »
« Reply #12 on: Monday,October 04, 2021, 06:38:48 AM »
The only Lotus specific 336 parts are the ring and pinion gears.
Offline bozman
« Reply #13 on: Monday,October 04, 2021, 08:00:59 AM »
Great.  Thanks for the info and input.  I will follow up later this week as we open up the trans.
« Reply #14 on: Monday,October 04, 2021, 08:53:59 AM »
I don't want to sound silly, but how did you determine that the transmission was in reverse?  Did you actually run the engine?  Also, what engine is it?
I cannot figure out in my mind how the transmission could be assembled with 4 reverse and one forward.
