Author Topic: Rear upright/drive axle, bearing assembly TCS  (Read 449 times)
Offline kram350kram
« on: Monday,September 27, 2021, 05:43:58 PM »
Any advise on assembly? Seems pretty straight forward, but thought I would ask. Thanks
Re: Rear upright/drive axle, bearing assembly TCS
« Reply #1 on: Monday,September 27, 2021, 08:10:22 PM »
Other than follow the manual, use Loctite 635 (green) on the splines of the half shaft. The Loctite called out in the manual is an obsolete number. r.d. enterprises used to sell small bottles of the stuff. I suspect they still do and is a good idea.
Offline Serge
    • Sleurs Motorsport
« Reply #2 on: Tuesday,September 28, 2021, 10:52:18 AM »
« Reply #3 on: Wednesday,September 29, 2021, 04:05:19 PM »
Use hardened spacers, the stock ones are crap.
There have been issues with double sealed bearings having too small an area on the inner race from spacers and yokes to bear against.  This leads to a bending movement that wears the surfaces and creates play.
