Author Topic: crossflow head installed  (Read 270 times)
Offline califkid_66
« on: Thursday,September 23, 2021, 10:36:15 AM »
finally installed my head !!
homemade alignment tools  went on real easy and is perfertly aligned
you can see where the distributor fits in
Re: crossflow head installed
« Reply #1 on: Thursday,September 23, 2021, 12:16:28 PM »
Nice!
« Reply #2 on: Thursday,September 23, 2021, 05:08:57 PM »
I'll second that, nice indeed.
Offline 1970S2
    • LOTUS EUROPA COMMUNITY
« Reply #3 on: Thursday,September 23, 2021, 08:02:10 PM »
Can  you give me the dimensions for the alignment tool...thanks
Offline califkid_66
« Reply #4 on: Friday,September 24, 2021, 03:35:39 AM »
 tool dimentions
  9.75 mm and 16 mm  that’s the tool you see in the last picture as for length
i sort of winged it  also i drilled a hole right through and put an allen key to be able to pull it out
after
i also used a long bolt same threads as head bolts but longer screwed it in
« Last Edit: Friday,September 24, 2021, 03:48:04 AM by califkid_66 »
