Author Topic: camshaft end cap cracked  (Read 306 times)
Offline califkid_66
« on: Thursday,September 23, 2021, 09:35:32 AM »
there seems to be a crack it doesn’t go right through did not seem to leak
leave as is and see what happens or get tig welded
Re: camshaft end cap cracked
« Reply #1 on: Thursday,September 23, 2021, 09:40:51 AM »
I don't know how stressed that part of the casting is but I'd be tempted to have it welded up.
Offline califkid_66
« Reply #2 on: Thursday,September 23, 2021, 09:46:52 AM »
that’s what i thought
thanks
« Reply #3 on: Thursday,September 23, 2021, 05:07:39 PM »
Are you sure it's a crack?  Looks more like a casting mark.  Welding will distort the housing such that it "may" require machining true again.
Offline califkid_66
« Reply #4 on: Thursday,September 23, 2021, 06:12:43 PM »
im not sure anymore i did think it was casting at first nice straight line but at the other end look like it was hit with a grinder i did try to look from inside couldn’t see any cracks i will check again tomorrow
Offline SwiftDB4
« Reply #5 on: Thursday,September 23, 2021, 06:26:40 PM »
I agree with JB. Looks like a casting mark. I wouldn't weld it due to heat distortion.
« Reply #6 on: Thursday,September 23, 2021, 07:15:48 PM »
I’m coming around to JB’s and Swift’s opinion. It does look like a casting imperfection and if it’s not leaking why try to fix it? It’s almost surely been there from the beginning so it’s been doing its job for how long?
Offline 1970S2
    • LOTUS EUROPA COMMUNITY
« Reply #7 on: Thursday,September 23, 2021, 07:58:50 PM »
DO A DIE PENATRATION TEST , TO CHECK FOR A CRACK, VERY EASY TO DO,  YOU APPLY A CLEANER, THEN SPRAY PENATREANT , THEN CLEANER, THEN DEVOLOPER, IF YOU SEE RED , ITS A CRACK
