Author Topic: KYB KG9125 front shocks for TC  (Read 491 times)
Offline 460384
« on: Monday,September 20, 2021, 03:19:56 PM »
I would like to know if KYB KG9125 shock will work for a Europa TC. Does Anyone has installed this shock on their front suspension? It is used on Triumph Spitfire and GT6, I think. If not, please let me know what would you recommend.
« Last Edit: Monday,September 20, 2021, 03:23:27 PM by 460384 »
Tom/Colorado
460432
Re: KYB KG9125 front shocks for TC
« Reply #1 on: Monday,September 20, 2021, 03:25:09 PM »
Does it have the protruding stud for the roll bar mount?
« Reply #2 on: Monday,September 20, 2021, 03:30:32 PM »
Rockauto lists it as having a stud on top.
https://www.rockauto.com/en/moreinfo.php?pk=502382
Offline 460384
« Reply #3 on: Monday,September 20, 2021, 04:15:59 PM »
No. it does not. So it will not work unless you skip the roll bar.
Tom/Colorado
460432
Offline 460384
« Reply #4 on: Monday,September 20, 2021, 04:18:06 PM »
I am a bit confused about this. A few websites show the correct top mount.
Tom/Colorado
460432
« Reply #5 on: Monday,September 20, 2021, 05:23:29 PM »
KYB does not list Lotus as a car they support.
The KG9125 is designed for the Triumph GT6, Spitfire, and Herald.
The short answer is that that (or any KYB shock) does not fit on a Europa.
« Reply #6 on: Tuesday,September 21, 2021, 03:15:28 AM »
Recommend...Banks/AVO or Spax, Gaz & Koni are suitable replacements.
« Reply #7 on: Wednesday,September 22, 2021, 08:19:19 PM »
All dampers will have (or should have) valving appropriate for their specified vehicle application.
Dampers are also 'tuned' to the associated springs . . more or less.
While it's probably quite possible to fit a particular damper to a number of different vehicles because the only constraints are the length and end fittings, it's likely the valving won't be correct.
