Author Topic: Rear brake drums TCS  (Read 293 times)
Offline kram350kram
« on: Friday,September 17, 2021, 06:02:23 PM »
Have four drums, but only one has the correct center hole diameter that centers on the hub. British Leland part # is 2LO4649, date code of 26D6. Not sure what the date code is, maybe 26 March 76?  Is this the correct OEM type unit? Seems a TR-7 uses this drum also. The other drums I have the center holes are much larger.
Re: Rear brake drums TCS
« Reply #1 on: Friday,September 17, 2021, 06:27:20 PM »
You have one right drum and three wrong.  The drum has to positively locate on the hub.
Offline kram350kram
« Reply #2 on: Friday,September 17, 2021, 06:42:20 PM »
Yes thanks, was just wondering if the correct drum was original equipment?
