Author Topic: 1st Autocross  (Read 5769 times)
Re: 1st Autocross
« Reply #30 on: Monday,October 11, 2021, 07:52:26 AM »
I suppose the way a cable would cause inaccurate readout would be is if it were broken and the driven end turned the other end slowly. That seems implausible to me though. Keeping the cable lubricated is important and often overlooked when bringing a car back to life after sitting for many years. I can’t remember what the appropriate lube is but I’d think it would be a mixture of gear oil and grease.
JB (and I) have electronic speedos. They are driven by “counters” that count revolutions. There are three types of counters that I know about. One (what I think JB has) that counts revolutions of the speedo gear in the tranny, another that counts revolutions of a spinning part of the car like a hub (IIRC, Clifton has this type), and a GPS antenna that translates distance into counts for the speedo. My speedo gear was eaten by my tranny so I chose the last type. Of course, it is useless in tunnels and dense tree cover. It also takes a couple of minutes to acquire satellites.
Re: 1st Autocross
« Reply #31 on: Monday,October 11, 2021, 08:28:22 AM »
+1  Your speed cable is "talking" to you.  Lube it now, before it's too late.
Offline rjbaren
Re: 1st Autocross
« Reply #32 on: Tuesday,October 12, 2021, 05:08:38 AM »
Do you guys just use spray lube, or do you use the lube devices with  the spray that I see for sale on the motorcycle websites?
Re: 1st Autocross
« Reply #33 on: Tuesday,October 12, 2021, 06:36:47 AM »
Pull the inner out and coat it with light grease.
Offline rjbaren
Re: 1st Autocross
« Reply #34 on: Tuesday,October 12, 2021, 03:20:32 PM »
I can almost unscrew the cable end behind the speedometer and after a while I'll probably get it.  Would it be best to undue the cable from both the speedo and the transmission and then pull the inner cable from the transmission end?
Re: 1st Autocross
« Reply #35 on: Tuesday,October 12, 2021, 04:11:13 PM »
It only goes one way, usually just from thew speedo head end.
