Author Topic: Which Renault engine can be used?  (Read 894 times)
Offline Lyngeled
« on: Tuesday,September 07, 2021, 10:32:48 AM »
Hi
I have an opportunity to buy an Renault engine, and the seller have some different types. Some look as the same rocker cover but with belts and pulleys on either ends or even both(?). The numbers I've is 807-10, 843j723 and a6ml752. I am not sure which have which belt/pulley placement. Can anyone tell me anything about this belt/pulley placement/engine type? (There is not too much room in front of the engine in the Europa).
Regards
Offline Lyngeled
Re: Which Renault engine can be used?
« Reply #1 on: Tuesday,September 07, 2021, 11:45:45 AM »
Pictures
« Reply #3 on: Tuesday,September 07, 2021, 01:21:16 PM »
You want the one with the water pump at the rear.  That’s the position that works in a Europa.  They have a cam with an extended rear section to mount the rear pulley.  You can adapt the other engines as long as you have that cam.
I notice the transaxle pictured is a five speed, possibly a 395.
« Reply #4 on: Tuesday,September 07, 2021, 06:35:46 PM »
The bottom picture looks like a cross-flow, grab it!
« Reply #5 on: Tuesday,September 07, 2021, 08:13:49 PM »
There are three crossflows.  Only one has the long cam and rear water pump.  Not sure what the fourth is.
« Last Edit: Wednesday,September 08, 2021, 04:58:20 AM by jbcollier »
« Reply #6 on: Tuesday,September 07, 2021, 10:44:04 PM »
Wonder how cheap they are, maybe worth the price of admission for the TS heads?
Offline Lyngeled
« Reply #7 on: Tuesday,September 07, 2021, 11:04:54 PM »
TS head?
Offline Lyngeled
« Reply #8 on: Tuesday,September 07, 2021, 11:11:57 PM »
The gearbox is a ng1034
« Reply #9 on: Wednesday,September 08, 2021, 05:05:28 AM »
TS or Gordini or crossflow.  They used the crossflow in the Renault 16TS thus it is sometimes called a TS head.
Having the head is only part of the battle.  A crossflow also uses a different:
- distributor (longer)
- camshaft (different valve order)
- pistons (valve pockets on both sides, different crown)
- exhaust manifold/header
- intake manifold(s) and carb(s)
Always best to try and find as complete an engine as possible.
Offline Lyngeled
« Reply #10 on: Friday,September 10, 2021, 08:25:38 AM »
... And what about the ng1034 gearbox? Is it one of the favourites?
Offline Lyngeled
« Reply #11 on: Friday,September 10, 2021, 08:28:36 AM »
Ok, this is a 697 and a gearbox that looks like the original one. Any opinions on that?
« Reply #12 on: Friday,September 10, 2021, 03:07:34 PM »
The 697 is a short stroke, 1470cc engine which revs cleanly and has a slightly higher hp output as compared to the later 1565.  Parts are available and the engine responds well to tuning.  The four speed transaxle is strong and gives few problems if the oil level is kept topped up.
Offline Lyngeled
« Reply #13 on: Saturday,September 11, 2021, 01:21:01 PM »
It seems that the only other than the 697 that works, is a 807 and complete with carburetor exhaust alternator and such. And it has a 352-11 which I don't want, I think.
« Reply #14 on: Sunday,September 12, 2021, 08:12:59 AM »
The gearbox on the 697 engine appears to be a 336?
Going by what looks to be an alloy lever on the cross-shaft, I suspect it's from a Renault 16 . . which means it's unsuitable for a Europa.
The only other engine that looks to be suitable is the 807 which has the water pump on the correct end and therefor, should have the longer cam.
The 352 gearbox should run in the correct direction for a Europa.
You'll need to check the spec of internal on this 352-11 to see if it's close enough to the 352's fitted to later Europas.
Be aware, the 352 was also fitted to the Renault 12 and had a shorter final drive, so, not suitable in my opinion.
The engine on the far left of the first pic looks like a 2 litre (or 2.2) OHC engine out of a Fuego, Renault 19 etc.
Here in Oz, the NG1 was used in the Renault 18 (I think). I'm not sure what Euro models carried it.
Stretching the memory but if I recall, it has a two spider diff . . which is fine.
Here's the NG manual:
http://www.lotus-europa.com/manuals/misc/ng.pdf
It all comes down to money and what you want.
Factor in that they'll all likely need a full rebuild.
If the engines are $50 each, I'd take all the 807's.
What is the asking price for the engines and gearboxes?
