It has always seemed strange that with gravity feed fuel tanks there is no way to shut off the fuel,for instance to change a fuel filter. So, purchased two fuel shut off valves from Summit,siphoned then drained the tanks,and fitted them close to each tank.Easy to reach if I need to shut off. Or,I can use one tank as a reserve.
