Author Topic: Cant get wiper motor to work  (Read 375 times)
Offline Sparkrite
« on: Friday,August 27, 2021, 10:22:47 AM »
This is on my federal 73 tcs,I have never seen the wipers  work. If I disconect the connection block at the motor and meter the different wires, I get 12v from each wire depending on the position of the stalk, except for the brown wire. It makes no difference what I do it doesn't show 12v.
There are no noises at all coming from the wiper motor when trying to use it either.
Re: Cant get wiper motor to work
« Reply #1 on: Friday,August 27, 2021, 11:52:51 AM »
Is the motor separately earthed?
There is a ring connector which goes under one of the long thin bolts which hold the casing together.
Offline Sparkrite
« Reply #2 on: Friday,August 27, 2021, 12:39:15 PM »
Yes, mine has that exact earth wire, infact it is two wires joined to that one ring connector.
« Reply #3 on: Friday,August 27, 2021, 01:09:57 PM »
Here's a site with detailed info on the wiring and diagnosis of 2 speed Lucas wiper motors:
https://www.gomog.com/BLAIR/tech/electrical/wipers/2speed/2SpeedWiperMotor.html
Offline Sparkrite
« Reply #4 on: Saturday,August 28, 2021, 03:38:52 AM »
Thanks for the link JB. I will give an update on how I get on.
Offline Sparkrite
« Reply #5 on: Saturday,August 28, 2021, 06:33:46 AM »
Went through the check list and my electrics are fine, which means the wiper motor had to come out for further investigation.
