Author Topic: temp gauge aftermarket problem s2 1969  (Read 241 times)
Offline mike alain
« on: Tuesday,August 24, 2021, 04:42:16 AM »
Folks,  all my gauges were toast after sitting in the sun and damp,   bought a set from China, looks same, even with the "smiths" logo,  but temp and oil pressure read too high,
could I put some sort of resistor to bring them down or do I try lots of 'senders' to find which one will work,  oil pressure with original reads 50 lbs, with new unit reads 100lbs,
thanks   Mike.
Re: temp gauge aftermarket problem s2 1969
« Reply #1 on: Tuesday,August 24, 2021, 06:49:33 AM »
Have you checked the voltage out of the voltage stabilizer? It should be 10v.
