Author Topic: need a seal carrier for a 336 gearbox 046F6021 ,  (Read 1565 times)
Offline 1970S2
    • LOTUS EUROPA COMMUNITY
« on: Thursday,August 19, 2021, 06:45:58 PM »
just took my engine out, separated the motor and gearbox, my seal carrier was broken , any out there ?.....Im in Ontario Canada...Thanks
Re: need a seal carrier for a 336 gearbox 046F6021 ,
« Reply #1 on: Thursday,August 19, 2021, 07:32:46 PM »
Welcome!
What exactly do you mean by "seal carrier"?
« Reply #2 on: Thursday,August 19, 2021, 07:34:44 PM »
Duh, figured it out.  You'll have to find a used one.
Offline 1970S2
« Reply #3 on: Friday,August 20, 2021, 03:28:59 AM »
the manual calls it the seal carrier, it is the shaft that carries the output seal on the transmission, it is also the shaft that the release bearing slides on, I will post a picture later
« Reply #4 on: Friday,August 20, 2021, 08:39:47 AM »
Surely the release bearing is around the input shaft, or first motion shaft, not the output shaft. The output shafts surely should be the splined diff outputs to which the rear driveshafts are fitted either side of the diff.
If the oil seal is around the first motion shaft and behind the clutch release bearing, the seal is located in the bell housing.
I think a photo is needed to dispel any doubt.
