Author Topic: I need new wheel hub bults  (Read 355 times)
Offline Adde
« on: Friday,August 13, 2021, 01:42:49 PM »
Hi,
I need new wheel hub bolts as my are crooked, (I don't know the correct name), but I refer to the 4 bolts in the rear wheel hub (see fig).
Anyone that know the dimensions, if thay are special for Europa or if i can use some standard dimensions, and where to buy them.
Also, is it the same for the front wheel hub, I was thinking that maybe it makes sens to buy a full set for all wheels at once.
Regards/Adrian
Re: I need new wheel hub bults
« Reply #1 on: Friday,August 13, 2021, 02:09:00 PM »
I assume you mean the wheel studs that the wheel bolts to. They are the same on all Europas.
Standard
https://www.sjsportscars.com/parts-and-accessories/SJ036C0009.htm
https://www.lotus-supplies.com/parts/wheels/misc/wheel-stud-all-bolt-on/
Same front and rear.
Offline Adde
« Reply #2 on: Friday,August 13, 2021, 02:15:36 PM »
Standard
Exactly, thanks a lot.
