Author Topic: V-8 project  (Read 67801 times)
Re: V-8 project
« Reply #90 on: Tuesday,May 23, 2023, 10:37:21 AM »
For reliability and unknowns, I try to not do things the factory or a professional race team would not do.
Any way to run an upper control arm?
If you consider an upper arm, this program is pretty useful.
https://vsusp.com/#0.8%26project_name%3Adefault%20values%26trim%7Bbody_roll_angle%3A0%7Cfront.left_bump%3A0%7Crear.left_bump%3A0%7Cfront.right_bump%3A0%7Crear.right_bump%3A0%7D%26front%7Bframe.susp_type%3A0%7Cframe.bottom_y%3A9200%7Cframe.center_to_upper_mount_x%3A28500%7Cframe.bottom_to_upper_mount_y%3A24000%7Cframe.center_to_lower_mount_x%3A17000%7Cframe.bottom_to_lower_mount_y%3A2400%7Ccontrol_arms.upper_length%3A24800%7Ccontrol_arms.lower_length%3A37500%7Cknuckles.hub_to_upper_x%3A15000%7Cknuckles.hub_to_lower_x%3A13000%7Cknuckles.hub_to_lower_y%3A13000%7Cknuckles.hub_to_upper_y%3A13000%7Cknuckles.hub_to_strut_axis%3A14000%7Cknuckles.strut_incl%3A8000%7Csteering.active%3A0%7Csteering.hub_to_outer_tie_rod_x%3A7620%7Csteering.hub_to_outer_tie_rod_y%3A7620%7Cwheels.offset%3A4000%7Cwheels.diameter%3A1500%7Cwheels.diameter_expl%3A35000%7Ctires.size_convention%3A0%7Ctires.section_width%3A19500%7Ctires.aspect_ratio%3A4500%7Ctires.diameter_expl%3A50000%7Ctires.width_expl%3A7620%7Ctires.compression%3A0%7D%26rear%7Bframe.susp_type%3A0%7Cframe.bottom_y%3A9200%7Cframe.center_to_upper_mount_x%3A28500%7Cframe.bottom_to_upper_mount_y%3A24000%7Cframe.center_to_lower_mount_x%3A17000%7Cframe.bottom_to_lower_mount_y%3A2400%7Ccontrol_arms.upper_length%3A24800%7Ccontrol_arms.lower_length%3A37500%7Cknuckles.hub_to_upper_x%3A15000%7Cknuckles.hub_to_lower_x%3A13000%7Cknuckles.hub_to_lower_y%3A13000%7Cknuckles.hub_to_upper_y%3A13000%7Cknuckles.hub_to_strut_axis%3A14000%7Cknuckles.strut_incl%3A8000%7Csteering.active%3A0%7Csteering.hub_to_outer_tie_rod_x%3A7620%7Csteering.hub_to_outer_tie_rod_y%3A7620%7Cwheels.offset%3A4000%7Cwheels.diameter%3A1500%7Cwheels.diameter_expl%3A35000%7Ctires.size_convention%3A0%7Ctires.section_width%3A19500%7Ctires.aspect_ratio%3A4500%7Ctires.diameter_expl%3A50000%7Ctires.width_expl%3A7620%7Ctires.compression%3A0%7D%26pref%7Bdiag1.px_per_mm%3A200%7Cdiag1.front_or_rear%3Afront%7Ctab.active%3A0%7Cunits%3A0%7Cshow.f%3A1%7Cshow.ca%3A1%7Cshow.k%3A1%7Cshow.st%3A1%7Cshow.stl%3A1%7Cshow.w%3A1%7Cshow.t%3A1%7Cshow.rc%3A1%7Cshow.rcl%3A1%7Cshow.ic%3A1%7Cshow.icl%3A1%7Cshow.fvsa%3A0%7Cshow.tl%3A0%7Cshow.kpil%3A0%7Credraw_during_drag%3A1%7Cchart.x_axis_center%3A0%7Cchart.x_axis_window%3A10%7Cchart.x_axis_num_steps%3A21%7Cchart.x_axis_field%3Atrim.body_roll_angle%7Cchart.y_axis_fields%3A%5BFR%5D.general.roll_center.y%7D
Offline SwiftDB4
Re: V-8 project
« Reply #91 on: Tuesday,May 23, 2023, 12:27:18 PM »
Agree with Clifton. Go for a twin link with an upper control arm. Not that hard to fabricate.
Offline kram350kram
Re: V-8 project
« Reply #92 on: Tuesday,May 23, 2023, 04:48:46 PM »
Thanks for the suspension program.   I don't find much fun in doing what has already been done. Will report on successes and failures when it runs down the road.
Offline kram350kram
Re: V-8 project
« Reply #93 on: Monday,July 17, 2023, 07:39:21 PM »
Thought I might need some extra leg room, had an old wheel so tried this. With the removable hub should make entry exit easier. Painting the body this week. Moving toward assembly.
Re: V-8 project
« Reply #94 on: Monday,July 17, 2023, 08:31:42 PM »
That came out pretty good!  :trophy:
Re: V-8 project
« Reply #95 on: Tuesday,July 18, 2023, 09:13:45 AM »
Interesting. Looks good. I like the idea of modifying an original part rather than aftermarket. Keeps more Lotus DNA in the project.
Offline kram350kram
Re: V-8 project
« Reply #96 on: Sunday,August 27, 2023, 06:24:02 PM »
Some final assembly progress on rear suspension, alternator mounting, engine, drivetrain, etc... exterior paint done except for final buffing. Will post pic's as assembly moves forward.
Re: V-8 project
« Reply #97 on: Sunday,August 27, 2023, 06:38:11 PM »
That’s looking great Kram!
Re: V-8 project
« Reply #98 on: Monday,August 28, 2023, 08:50:01 AM »
Wow! There's a lot going on there. Nice looking work.
Offline kram350kram
Re: V-8 project
« Reply #99 on: Monday,August 28, 2023, 07:07:26 PM »
A few more pic's.
Re: V-8 project
« Reply #100 on: Monday,August 28, 2023, 07:18:59 PM »
Beautiful work, Kram!  :beerchug:
Re: V-8 project
« Reply #101 on: Tuesday,August 29, 2023, 03:09:42 AM »
What are we looking at in that second pic Kram, Twin link rear suspension? Got a pic from a different angle?
Offline S2Zetec54
Re: V-8 project
« Reply #102 on: Tuesday,August 29, 2023, 12:34:20 PM »
Have a look at reply 83…..it is a retention system
Re: V-8 project
« Reply #103 on: Tuesday,August 29, 2023, 02:07:01 PM »
Oh yeah, forgot about that.
Offline kram350kram
Re: V-8 project
« Reply #104 on: Tuesday,August 29, 2023, 05:28:26 PM »
I like the term "Retention system". I hope it does!
