Author Topic: Vacuum take off  (Read 348 times)
Offline europa88
    • Europa88
Vacuum take off
« on: Wednesday,July 28, 2021, 06:55:17 AM »
Hi does anyone know what the thread size and type is on the vacuum take off on a Dellorto inlet manifold?
I have removed the brake booster and want to blank it off neatly (I currently have a short bit of hose and a bolt with worm drive clips
Offline MRN I J
    • Four Ashes Garage
Re: Vacuum take off
« Reply #1 on: Wednesday,July 28, 2021, 11:06:01 AM »
most likely 1/8 bsp as thats been industry std for many years on servo take offs, just a bit bigger than 3/8 at 0.383" od, taper plugs are easily available.
Regards Chris
other cars inc wifes cars
Offline europa88
    • Europa88
Re: Vacuum take off
« Reply #2 on: Wednesday,July 28, 2021, 01:14:05 PM »
Thanks Chris  :)
