Author Topic: 1972 Europa with 2 Strombergs Idle starting point  (Read 318 times)
Offline marks
« on: Monday,July 19, 2021, 07:29:21 AM »
I am getting close to finishing my 72 Europa.  I found out that the setting on the linkage between the two Stromberg 175 CD 2 carbs was way off.  Is there a starting point to set the carbs (like a small drill bit) for the butterfly valves?  I appreciate the help!  Mark
Re: 1972 Europa with 2 Strombergs Idle starting point
« Reply #1 on: Monday,July 19, 2021, 10:18:54 AM »
I start with 1 to 1.5 turns off fully closed.
Offline marks
« Reply #2 on: Tuesday,July 20, 2021, 06:54:50 AM »
I really appreciate that information.  Thank you very much!  Mark
