Author Topic: Battery drain  (Read 1795 times)
Offline rjbaren
Re: Battery drain
« Reply #30 on: Friday,July 23, 2021, 08:30:14 PM »
So far, yesterday the battery voltage was 12.95.
12 hours later the voltage was 12.95
12 hours later the voltage was 12.93
12 hours later the voltage was 12.91
So I hope the relay I replaced was the culprit that killed two batteries in three weeks.  I tested the relay I removed, there are four tests and I performed three, and it passed the three tests.  I have to make up some wiring to do the fourth test.
I am going to leave the battery disconnect in place and put the extra weight out of my mind.
Offline rjbaren
Re: Battery drain
« Reply #31 on: Saturday,July 24, 2021, 02:09:07 PM »
I drove the car today.  Before I left the battery was at 12.91 volts.  I have not had the fuse in the radio and have not yet replaced it.  After the drive the battery voltage was 13.03 volts.
I think I am going to repeat the test again with the radio fuse installed and see if there is a difference.
Re: Battery drain
« Reply #32 on: Saturday,July 24, 2021, 04:57:46 PM »
Does your radio store settings that requires constant juice to it? It seems like an unlikely source of your problems but something I thought about because my radio has that.
Offline rjbaren
Re: Battery drain
« Reply #33 on: Sunday,July 25, 2021, 05:02:22 AM »
Yes, I believe it will remember stations, EQ settings, and power the clock.  Maybe more.
