Author Topic: Output shaft yokes  (Read 1334 times)
Re: Output shaft yokes
« Reply #15 on: Tuesday,August 03, 2021, 08:59:45 AM »
If in doubt if the holes in the yoke and shaft are lined up, try pushing a drill bit of the right size (5mm) through the holes.
« Reply #16 on: Tuesday,August 03, 2021, 09:19:36 AM »
As for cutting the drive shaft, that will be Plan C.
I hope getting adjustable lower links is part of either plan A or B.
« Reply #17 on: Tuesday,August 03, 2021, 10:42:14 AM »
Adjustable lower links is a 'someday' plan, whenever I get around to upgrading the entire suspension system. It may be necessary for plan A (fitting the yoke as is), but Plans B (re-drilling the 5 mm pin hole) & C (shortening the drive shaft) both result in restoring the dimensional aspect of the length of the drive axle assembly to a factory spec.
