Author Topic: fuel starvations solved !  (Read 861 times)
Offline califkid_66
« on: Monday,July 12, 2021, 09:45:00 AM »
drove the lotus a lot this week needed to clear my head so just went for a ride to mont tremblant
but on the way back being on wavy roads i pushed it a bit ! and it was hesitating so i thought ok not enough fuel bad fuel pump floats not adjusted right maybe fuel filter
so went with the simplest fuel filter it was new only 400 miles on it i emptied it on a towel you can see what came out
changed it  problem solved run great
Re: fuel starvations solved !
« Reply #1 on: Monday,July 12, 2021, 10:18:40 AM »
Glad you found your problem! That is an easy fix!
Offline califkid_66
« Reply #2 on: Monday,July 12, 2021, 10:32:01 AM »
yes im glad it was only that so now i carry a spare fuel filter  i also carry points and a spare voltage regulator so i think im covered
Offline Sandyman
« Reply #3 on: Monday,July 12, 2021, 10:49:03 AM »
Possibly time to clean and seal the fuel tank this winter.
Offline Dilkris
« Reply #4 on: Monday,July 12, 2021, 12:15:13 PM »
That's a lot of debris - any idea what it is..??
« Reply #5 on: Monday,July 12, 2021, 12:39:29 PM »
It's corrosion from the tank(s).
Offline califkid_66
« Reply #6 on: Monday,July 12, 2021, 02:19:46 PM »
actually it’s not corrosion there is no rust in the tanks i took a picture when they were empty and they looked galvanized it looked like sand but when dried out it was just dirt maybe from jerrycans
just glad i had an in-line filter
« Last Edit: Monday,July 12, 2021, 03:00:36 PM by califkid_66 »
« Reply #7 on: Monday,July 12, 2021, 02:57:51 PM »
I had that happen on mine in under 50 miles. I "thought" I had my tank pretty clean prior. Glad it was a cheap, easy find and fix.
Offline califkid_66
« Reply #8 on: Monday,July 12, 2021, 03:04:07 PM »
me to im gonna keep a close eye on the filter in case there is some dirt left
« Reply #9 on: Monday,July 12, 2021, 04:58:30 PM »
It can be corroded just in a few spots, seams, inside a pipe, etc.  You can't alway tell just by looking.
Offline califkid_66
« Reply #10 on: Monday,July 12, 2021, 05:51:08 PM »
if it is corrosion there isn’t a lot they were empty for a while so it’s very possible but im still hoping it was dirt time will tell i got the new filter in an i keep an exra one in case
just one question the s2 federal tank i read somewhere is 8 gallon is it imperial or us and is it really 8 gallons per side thanks
« Reply #11 on: Monday,July 12, 2021, 09:42:08 PM »
Fit a filter like this:
https://www.burtonpower.com/filter-king-fuel-regulator-filter-85mm-glass-bowl-fsefpr006.html
You can see what's going on and a far larger capacity.
« Reply #12 on: Monday,July 12, 2021, 09:42:59 PM »
« Reply #13 on: Tuesday,July 13, 2021, 09:25:51 AM »
That looks like a nice piece. The page at the link seems to suggest it does double duty as a pressure regulator.
Offline califkid_66
« Reply #14 on: Tuesday,July 13, 2021, 04:21:59 PM »
 i like it it’s got a period look and bonus it’s a fuel regulator to
