Author Topic: 3776R unusual clutch action  (Read 1484 times)
Re: 3776R unusual clutch action
« Reply #15 on: Wednesday,June 16, 2021, 08:16:01 PM »
You can't disengage the clutch by hand using the bell housing lever.  Is there anyone in your area familiar with Europas that could try the clutch?
« Reply #16 on: Wednesday,June 16, 2021, 10:02:26 PM »
As I put it into first gear and tried to slowly let out the clutch, it was very hard to keep gradual, it just bit and lurched forward. I have barely driven it a few yards but at least the clutch is not seized and I can engage 1st and reverse gear. The problem is the clutch pedal needs more pressure than any other car I have driven and in particular at the biting point. Is this normal and if not what could it be,( note the car had been unused for about 20 years).
Firstly, I'm surprised that after such a long time the clutch works, I've often had to free mine off after only a winter of sitting in the garage.
Trying to compare with a modern car is tough, mainly because my version of "harsh" might be someone else's "normal". But I'd say that the TC Europa clutch is heavy, certainly compared with the same engine and virtually the same clutch in the Elan and definitely compared with a modern car.
A couple of things - firstly it's a cable clutch with a relatively long cable run whether or not you have the outer cable stopped at a chassis-welded bracket or the engine mounted one. With the cable layout on the Europa there's got to be some friction even if it's small compared with the force your foot exerts. It's a personal thing but I find hydraulic operation tends to be smoother than cable even if cables are still used in some modern cars. Going back to the Elan, that has hydraulic operation and feels "modern".
Secondly, the pedal leverage and pedal platform are small compared with most modern cars (and even the 1960s Elan) so the pressure on the ball of your foot will seem higher.  I could imagine anyone thinking it's "all or nothing" in operation.
My clutch is relatively new and I'd say it's more difficult to manoeuvre slowly than other cars we own but it's just a learning curve. Once you've driven the car around a few times it becomes "that's what this car feels like" and your mind copes accordingly.  Once you're moving along I don't notice it as unusual, it's just starting off that my mind says "heavy clutch".
« Reply #17 on: Thursday,June 17, 2021, 08:44:18 AM »
What condition are the engine/trans mounts in? I would think that of they were worn or loose or particularly soft in some way, it would exacerbate the problem of clutch take-up when the cable is retained at the frame. Just a thought.
Offline Dilkris
« Reply #18 on: Thursday,June 17, 2021, 10:51:48 AM »
Sorry to ask a maybe stupid question - but what car are we talking about here?? S1,S2,TC?
I have a TC (TCS) and have both a chassis mounted clutch cable anchor point AND an engine mounted anchor plate, (the latter as per picture posted by ARIZONA previously in this thread).
(Again - sorry - I am unable to recognize model series by chassis numbers.)
Offline Lotsof 3146 R
« Reply #19 on: Thursday,June 17, 2021, 11:09:39 AM »
My 3496R has it on the chassis...when did it switch? What does the engine mounted bracket look like?
Hi please see attached the service bulletin. I used some pan head Allan bolts to fit
« Reply #20 on: Thursday,June 17, 2021, 12:03:12 PM »
I cut the old bracket off the chassis when the engine was out (extra weight!) before bolting the new bracket to the block.
