Author Topic: Pedal mounting bolt pattern?  (Read 744 times)
« on: Monday,June 07, 2021, 12:30:06 PM »
I need the pedal mounting pattern so I can drill my T-section repair piece. Is there a drawing of the pedal assembly with dimensions?
The old piece was too rusty for an accurate measurement and the holes in the body have been wallowed out ....
I get a measurement of 4-3/8 x 1-9/16"  :confused:
Re: Pedal mounting bolt pattern?
« Reply #1 on: Monday,June 07, 2021, 01:19:26 PM »
This drawing is the closest thing I could find to what you want (https://drive.google.com/drive/folders/1szP1L6-cHpjrGMF2dAiyQrY_aR-ZWDJM). It came from the old lotuseuropa yahoo group. Before yahoo closed their groups down, our own EuropaTC collected all the files and organized them into sections and put them on a google drive. The whole collection might be useful (https://drive.google.com/drive/folders/1uOmTsXhIF3qlutvCvmY8sAaliwc8Rwbj).
« Reply #2 on: Monday,June 07, 2021, 01:38:49 PM »
 :confused: don't see what I am looking for... had to get my son to help open with Autodesk viewer....
« Reply #3 on: Monday,June 07, 2021, 01:57:58 PM »
It looks my guesstimate was correct! 4-3/8 x 1-9/16"
Thanks BDA!
Offline gideon
« Reply #4 on: Monday,June 07, 2021, 02:16:11 PM »
Turbo, this is a drawing of the pedal assembly base plate.
https://groups.io/g/LotusEuropa/files/Tandem%20Master%20Brake%20Cylinders/Pedal%20Assembly%20Base%20Plate.pdf
If you don't have access then join the Lotus Europa group on groups.io .
« Reply #5 on: Monday,June 07, 2021, 02:33:15 PM »
   This is my original piece that was cut off for an S2 fed . I’ll put measurements on it if it’s what you want.
« Last Edit: Monday,June 07, 2021, 02:43:27 PM by dakazman »
« Reply #6 on: Monday,June 07, 2021, 03:16:48 PM »
The file is a pdf - I tried to give you the link to the pdf but my link seems to only get you to the menu for "A - Chassis". Go to the "Lotus europa chassis drawing.pdf. A few pages down is where the 'T' part of the frame and the pedal attachment is.
edit - I see that you found it, Turbo! Between that drawing and the drawing gideon sent you, you should be in pretty good shape!
« Last Edit: Monday,June 07, 2021, 03:19:30 PM by BDA »
« Reply #7 on: Monday,June 07, 2021, 04:10:41 PM »
Thanks to all! I will be also refabricating my pedals too, I will make sure they match ;)
