Author Topic: More parts today, El Camino exhaust system.  (Read 1291 times)
« on: Thursday,June 03, 2021, 05:07:58 PM »
   The 2 1/2” tube showed up yesterday afternoon. Laid out the rest of it from headers back. Making the x pipe is a little tricky but I got a good jump on it. Second pic is what I’m copying.
Re: More parts today, El Camino exhaust system.
« Reply #1 on: Thursday,June 03, 2021, 05:28:03 PM »
Good luck, D'man! Show us the finished product!  :BEER3:
« Reply #2 on: Wednesday,June 09, 2021, 03:34:14 PM »
  This has been a battle, since the 84 El Camino’s. We’re not dual exhaust . I modified the crossmember years ago but never put a complete system on . I went to the local exhaust shop and received a price of $850. Plus tax for a headers back system. For approximately 300.$ I received all the pipes necessary to do the job.
  It was so much easier when I did this on car with a lift and all the tools needed.
  Tomorrow I’ll weld it up .😀
« Reply #3 on: Wednesday,June 09, 2021, 10:07:23 PM »
Did you use a tube expander on those tubes or did they come with one end already expanded ?
I only ask because I bought an expander and promptly broke it when I tried on a stainless tube. Mild steel was ok, stainless just too much so if you've managed to do it I'd be interested in what kit you used ?
« Reply #4 on: Thursday,June 10, 2021, 01:35:16 AM »
 Brian ,
   The 2.5” steel tubing came with one end expanded. I went back and forth laying out so to use as little material as possible . The expanded portion was a healthy 3” depth, so I made short rings to go around one tube to change the way the muffler fit .
  Previously I worked in a muffler shop with a lift, hydraulic bender and expander etc. , why buy a kit ?
Just ask a shop to expand a pipe or two for you. Some will work with you so I would call around first.
Here in Florida we don’t go through exhaust systems as fast as up north with the sleet/snow and salty roads. These steel tubes are rusting as soon as I took them out of the plastic packing sleeves.
   👍Stainless is much better 👍
« Reply #5 on: Thursday,June 10, 2021, 05:21:11 PM »
  Sorry BDA, not finished yet.
  All tax welded up and recheck good . Took it out again and welded it up and painted due to it starting to rust.
  The view from the ground was amazing. Then I realized I may be to close.
« Reply #6 on: Thursday,June 10, 2021, 05:32:21 PM »
I’m patient.  :)
« Reply #7 on: Thursday,June 10, 2021, 06:34:23 PM »
Ni ce job!
« Reply #8 on: Friday,June 11, 2021, 05:28:02 AM »
  I like the view from down here too …
« Reply #9 on: Friday,June 11, 2021, 06:58:07 AM »
Shiny!
« Reply #10 on: Friday,June 11, 2021, 05:02:57 PM »
  Love the words “comin’ down” . 😃
    All most completely satisfied except I hung one muffler a tad to high and tack welded. I’ll bring it to a shop to adjust, drop down slightly because I could not get the correct angle to see with my helmet on .  I learned Indian when some s  po arks went into my ear. . 😁
  You can see from the rear the right side needs to be turned counterclockwise which will turn the tip down and stop hitting the bumper.
« Reply #11 on: Friday,June 11, 2021, 05:23:10 PM »
No criticism here! I'd be absolutely even more useless at this than the stuff I try to do!  :beerchug:
« Reply #12 on: Friday,June 11, 2021, 06:21:20 PM »
   Thanks BDA ,
 I’m here for you . We all have our own skills. It’s not perfect yet but a big improvement . The pulse of the exhaust sound is different over the straight pipes and the engine feels much smoother.
