I would like to do some experimenting with rear stub axles and uprights. I'm looking for just about any stub axle. For example, if the threaded end has broken off or the u-joint ears are busted, that would be ok.
I'm also interested in a junque upright. Here, I'm a little confused because I'm primarily interested in a TC upright (I believe that the only difference between the TC and TCS is the bolt circle of the mount to the radius arm - if that is true, it doesn't make any difference whether it is a TC or TCS upright. I'm really only interested in the dimensions related to bearings, stub axle, etc. It does not have to be serviceable.
Let me know what you have and what you want for it and we'll probably be able to make a deal.
