Author Topic: Aston/Monza Fuel cap to fit S1 Europa 2" Fuel tank neck  (Read 1054 times)
Offline Tim Humphreys
« on: Friday,May 07, 2021, 04:43:13 PM »
Hi Team,
my first post, has anyone sourced an Aston or Monza fuel cap to fit the standard 2" fuel filler behind the Europa rear window?
Tim Humphreys Melbourne Australia
Re: Aston/Monza Fuel cap to fit S1 Europa 2" Fuel tank neck
« Reply #1 on: Friday,May 07, 2021, 05:18:51 PM »
Sorry I can't help you with your fuel cap question but I wanted to make sure I did this:
 :Welcome: Tim Humphreys!!!
« Reply #2 on: Friday,May 07, 2021, 07:35:21 PM »
Hi Tim,
You mean like the ones Serge Sleurs fitted to his S1?
https://www.youtube.com/watch?v=fSnQlnpYpQg&t=1s
I like the look but to me there's competing issues.
The small ones look too dinky for my taste.
The large ones are fairly cramped.
Offline literarymadness
« Reply #3 on: Friday,May 07, 2021, 08:53:44 PM »
Offline lotusfanatic
« Reply #4 on: Saturday,May 08, 2021, 12:01:31 AM »
Hello Tim,
« Reply #5 on: Saturday,May 08, 2021, 12:21:26 AM »
Hi Tim.
Is there any reason you dont want tu use the Twin Cam flip top fuel caps? I would have thought they would be a simpler fit.
« Reply #6 on: Saturday,May 08, 2021, 04:20:44 AM »
 :newhere:
Thx All, where can I purchase a Twin Cam Flip type, trying not to have to cut /weld  the fuel neck or cut larger holes in the body such as Serge did .
« Reply #7 on: Saturday,May 08, 2021, 06:11:52 AM »
They are basically the same as a Triumph TR6.  No idea if the TR6 filler pipe matches as well.
« Reply #8 on: Saturday,May 08, 2021, 06:42:05 AM »
Try eBay. Motor bikes have the same type.
« Reply #9 on: Saturday,May 08, 2021, 07:23:36 AM »
This is in the UK https://www.sjsportscars.com/parts-and-accessories/SJ074L0001.htm
The tube on the bottom passes through a rubber grommet in the body and is connected to the tank via a rubber hose. I don't think you can replace just the cap as the hinge fitting is on the top of the pipe.
Offline Exlimey
« Reply #10 on: Saturday,May 08, 2021, 07:51:38 AM »
This the thing you are looking for?
« Reply #11 on: Saturday,May 08, 2021, 10:09:44 AM »
For that price I will use one of them for my Bradley VW kit car in place of my original Triumph GT6 filler assembly.
« Reply #12 on: Saturday,May 08, 2021, 03:33:18 PM »
Thx Guys,
started with bike fittings, hard to find with 2" neck, otherwise cutting and welding, will also look to the TR6 fitting.
« Reply #13 on: Saturday,May 08, 2021, 08:26:30 PM »
TR Spitfire may be a tad smaller than TR6.
Offline S2Zetec54
« Reply #14 on: Sunday,May 09, 2021, 03:43:55 AM »
Hi Tim, welcome to the forum and thank you for posting the thread.
I have an S2 type 54 and my fillers are both only key operated...which is a bit of a bore and one more key to have on the ring. Do the twin cam ones have to be locked or can you just have them on the button? I had them on my last but I just can't remember
Many thanks and good luck Tim
