Author Topic: petronix ep141  (Read 565 times)
Offline califkid_66
petronix ep141
« on: Sunday,May 02, 2021, 01:25:37 PM »
i just recieved my ep141 supposed to be simple installation but i just can’t figure it out the instructions are very vague do i have the right part
if so please show me how
thanks
Offline MRN I J
    • Four Ashes Garage
Re: petronix ep141
« Reply #1 on: Sunday,May 02, 2021, 01:28:56 PM »
For Renault engine with Ducelier distributor ?
Regards Chris
other cars inc wifes cars
Offline califkid_66
Re: petronix ep141
« Reply #2 on: Sunday,May 02, 2021, 01:40:02 PM »
yes it seems to screw from underneath i thought i just had to remove the points slide the sensor and screw the end with the ground but doesn’t seem to fit
Offline califkid_66
Re: petronix ep141
« Reply #3 on: Sunday,May 02, 2021, 02:25:47 PM »
i tried putting it in not enough space to clear for magnet
help !! before it drives me crazy!!
thank you !
Re: petronix ep141
« Reply #4 on: Sunday,May 02, 2021, 03:21:37 PM »
That's the wrong one.
I went to check mine but it's a Bosch distributor from a crossflow so not the same.  You definitely do not have to remove the points plate.
« Last Edit: Sunday,May 02, 2021, 03:24:55 PM by jbcollier »
Offline califkid_66
Re: petronix ep141
« Reply #5 on: Sunday,May 02, 2021, 03:25:12 PM »
i ordered ep141  what would be the number for the renault ducelier
« Last Edit: Sunday,May 02, 2021, 03:27:20 PM by califkid_66 »
Re: petronix ep141
« Reply #6 on: Sunday,May 02, 2021, 03:33:32 PM »
Hmm, I think you did get the right one.  I just check the Pertronix site.  Wait until a lister who's don it before chimes in.  You should not have to remove the points plate.  It should go where the original points went.
Offline califkid_66
Re: petronix ep141
« Reply #7 on: Sunday,May 02, 2021, 03:39:09 PM »
i think i can make it work i was wondering why i had no little plexiglass to adjust air gap but im not sure but i think i figured it out if you look at the picture the igniter is leaning against a little piece of teflon if i removed it the ignitor will sit flat in the back and the plate from the points will push it and hold it in place and i would have enough space for the magnet and the correct air gap
Offline califkid_66
Re: petronix ep141
« Reply #8 on: Sunday,May 02, 2021, 03:45:54 PM »
thanks jp i think you have to use the points plate to hold it in place in the picture i just placed it against the back iits not pushed all the way down im on top of the teflon but that would be where it would end up and seems to be good just would like to conferm  it might help somone in the future
Re: petronix ep141
« Reply #9 on: Sunday,May 02, 2021, 07:42:54 PM »
The old points and condenser are removed before fitting the ignitor.
Offline Pete
Re: petronix ep141
« Reply #10 on: Monday,May 03, 2021, 07:59:13 AM »
This is how mine looked. But it was a hot sparks one
Europa S2 1970 great car
Me complete novice mechanic..
Offline califkid_66
Re: petronix ep141
« Reply #11 on: Monday,May 03, 2021, 09:35:00 AM »
thanks Pete to bad it’s not the same as mine im still trying to figure out how to install it it should be the right one ep 141 for ducellier
Offline califkid_66
Re: petronix ep141
« Reply #12 on: Monday,May 17, 2021, 12:06:50 PM »
finally figured it out started first try runs smooth and bonus the tacometer works
the instructions did not help to adjust the space between the magnet and sensor i just bent the bracket in back of the sensor i used the same clip that was holding down the points and the non movable part of the points is pushing on it to eep it in place
