Author Topic: Sebring Mirrors  (Read 1256 times)
Sebring Mirrors
« on: Monday,April 19, 2021, 09:08:05 PM »
https://www.ebay.com/itm/SEBRING-RACING-MIRROR-FERRARI-PORSCHE-356-911-550-VINTAGE-ACCESSORY-CHROME-NOS/372870753822
I have no affiliation to the sale or seller, for information only.
When I purchased 2943R...in 1974 (May 73 production) it came with these on the car, the real deal pot metal chromed...stamped Sebring. Some leftovers no doubt, collecting dust and needed to be moved into production.
To find a pair of these in original condition, you'd be better off to surrender one of your fingers like the Japanese mobsters require. Just look at the asking price...I wonder if this seller would consider organ harvesting instead of cash?
« Last Edit: Monday,April 19, 2021, 09:25:01 PM by Lou Drozdowski »
Offline lotusfanatic
Re: Sebring Mirrors
« Reply #1 on: Monday,April 19, 2021, 09:19:51 PM »
 Thanks for the share Lou...
$2,995?!  :huh:
Offline Sparkrite
Re: Sebring Mirrors
« Reply #3 on: Tuesday,April 20, 2021, 06:29:22 AM »
Recently sold
https://www.ebay.co.uk/itm/2x-VITALONI-SEBRING-MACH-1-WITH-Genuine-PORSCHE-Mount-911-944-SC-WING-MIRROR/114762194449?_trksid=p2504926.m5232.l9681
Sparkrite...
Vitaloni are re-pops in plastic, usually sell for under $100.
 I have a set on  3307R now, they don't have the quality finish and are quite flimsy. The shape compared to original has more of a tear drop, instead of the rounded style. The mirror is also a tad larger..I still have a early production version of Sebrings and wanted to swap the glass...no dice.
Re: Sebring Mirrors
« Reply #4 on: Tuesday,April 20, 2021, 10:43:21 AM »
Were the Sebring Mach 1 mirrors also available in plastic? My 73 Federal Special is fitted with what I'm quite sure are its original mirrors, Sebring Mach 1, but the housing seems to be plastic (though admittedly, it's hard to tell).
Re: Sebring Mirrors
« Reply #5 on: Tuesday,April 20, 2021, 11:29:25 AM »
Those appear to be the original chromed pot metal mirrors. The plastic ones that came later have a much thicker cover..
Re: Sebring Mirrors
« Reply #6 on: Wednesday,April 21, 2021, 08:51:15 AM »
Cheers BDA. On closer inspection, I believe you are right, they are metal housings. But it is really difficult to tell. They have the feel and sound (when tapping on them with a metal rod) of plastic.
Re: Sebring Mirrors
« Reply #7 on: Wednesday,April 21, 2021, 08:56:35 AM »
Since "pot metal" is basically zinc, I believe, it would be difficult to tell non destructively. You could take the cover off the mirror and scratch the inside to make sure but I would be very surprised if those covers were plastic.
Offline Vegantune
  • 47+ Years Europa TCS /JPS Owner/Fixer/Improver
Re: Sebring Mirrors
« Reply #8 on: Wednesday,April 21, 2021, 10:37:55 AM »
The ones on eBay are original version all-metal, probably very early to mid-'60's era, recognizable by the full 360° wraparound solid housing with no separate slotted base. These were available with both flat and convex mirrors. Later on, Moss added chrome plated over conductive primed plastic (see photo of example of broken tail with white plastic core visible). The plastic ones are generally recognized by a housing that has an open slot on the bottom (also seen in first picture) that slides into a raised black plastic base. The base incorporates the spring loaded adjustable mirror, and uses a long screw seen on the mirror side of the black base that extends to a metal threaded socket in the tail of the detachable chrome cover. BTW, this long screw does rust, making removal of the housing impossible without serious damage.
The old style all metal ones were typically bolted directly to the car as one piece without any added base, while the plastic ones were all two-piece with slightly raised black base/mirror assembly that mounted first, then chrome plastic housing cover slides on, and is secured with the long screw. I’ve never seen any of the all metal units on any Europas, but it could be someone replaced theirs for whatever reason, maybe damage, back when you could still find metal ones and the few transitional metal ones on various wrecked race cars.
If you have the black plastic base with visible small screw head and a gap in the chrome on the bottom of  the housing, tap on it, and if its a hollow dull thud, it is chrome plated plastic, not metal. But there is another very simple way to verify whether you have metal or plastic. If they have “Mach 1” under “Sebring” on the housing, they are chromed plastic. The original metal ones were only marked “Sebring” without “Mach 1” like the metal ones on eBay, except for a few during transitional metal to plastic that were a sort of hybrid, and had both words on a single line, not one over the other. Or you could remove the chrome shells via that small front screw head, and you will know they are way to lite to be metal at less than 3 ozs. each. But if the screw won't budge, it probably has rusted to the metal socket in the nose, so don't push you luck if it doesn't want to turn.
The much newer Vitaloni and other knock-offs are even easier to spot. All have a somewhat larger front housing section than any original Sebrings, with a thick roll-over lip around a larger convex mirror. They are also available in solid black. Although construction with the slotted base is essentially the same, an original housing will not swap onto the Vitaloni base. The older ones use a long fine threaded machine screw into a metal nut receiver secured inside the nose of the chromed plastic housing, while the new Vitalonis ones use a longer coarse-threaded screw directly into a short plastic molded tube in the housing nose -- which can strip fairly easy if you over-tighten. Otherwise, these new copies are easy to find and cheaper if not quite as sturdy, but they do have one other benefit: a wider panorama using a larger and convex mirror rather than a smaller flat one.
I think this seller could eventually get a very serious price - maybe not quite this much, but who knows? And having original box and papers as further proof of pristine condition will add more. The supply of both the metal and original plastic ones in new condition is only shrinking. I have two pairs of original plastic “Mach 1” versions I may put up on eBay at some point (see pictures), but updated with stainless steel long screws that can’t rust. For someone sitting on a £3-10M+ car that came OEM with either ultra rare all metal mirrors or later rare plastic, what's a few extra 100 quid for 100% correct pristine or NOS part where anything non-original only devalues the vehicle? Both Sebring versions were factory and/or US DOT compliant import originals for a number of vintage Ferrari, Lamborghini, Maserati, Bizarrini, and more than a few vintage race cars -- not exactly a short list of potentially serious buyers for genuine NOS or close to it, willing to pay a premium for maintain authenticity.
« Last Edit: Monday,April 26, 2021, 11:34:42 PM by Vegantune »
- A Norwegian Blue with beautiful plumage is still nothing but a dead parrot.
1973 Black Europa TCS/Vegantune JPS #180
1973 White Europa TCS
2012 Jaguar XJL 5.0 Supercharged
1975 Ferrari Dino 308 GT4
1994 Volvo 940 Shoebox Wagon
2005 Yamaha V Star
1998 Kawasaki XII Voyager
Re: Sebring Mirrors
« Reply #9 on: Thursday,April 22, 2021, 08:47:37 AM »
Thanks for the comprehensive report on Sebring mirrors. Very helpful.
