Author Topic: Electrics help  (Read 492 times)
Offline Pete
Electrics help
« on: Thursday,April 15, 2021, 12:05:01 PM »
Okay. So I have got the car running. The volt reader bounces like crazy tho.
The indicators work. When you pull full beam headlights they come on. Oil warning light comes on and the indicator warning light comes on.  But no other electrics work. Normal lights don’t. Interior lights don’t. Electric windows or radio don’t work.
I’m not sure where to start.
Any thoughts?
Europa S2 1970 great car
Me complete novice mechanic..
Re: Electrics help
« Reply #1 on: Thursday,April 15, 2021, 12:25:40 PM »
First check the fuse block.  Clean all its connections and the fuses.  If it's bad, consider replacing it.
Then use the wiring diagram and work through all the ground points next.
After that, use the wiring diagram and work your way through each circuit.
Offline Pete
Re: Electrics help
« Reply #2 on: Thursday,April 15, 2021, 12:48:01 PM »
Where will I find the fuse block? I did find a brand new one on the work bench with a load of new fuses and clips in a bag.
Re: Electrics help
« Reply #3 on: Thursday,April 15, 2021, 12:55:12 PM »
The fuse block is on the tunnel just behind the dash. On a US car, it is on the passenger side. I don't know if that changes for the Brit cars.
Offline Pete
Re: Electrics help
« Reply #4 on: Thursday,April 15, 2021, 12:57:34 PM »
Cheers.
I’ll take a look tomorrow.
This forum. Is extremely useful for a complete novice Lotus owner/ mechanic. Lol
Re: Electrics help
« Reply #5 on: Thursday,April 15, 2021, 01:25:47 PM »
Do you have the manual & wiring diagrams ?
wiring diagram for the S2
http://lotus-europa.com/manuals/misc/electrical/s2-diagc.gif
loads of electrical stuff here, scroll down the page
http://lotus-europa.com/manuals/index.htm
Are you measuring voltage at the battery when you say the voltage fluctuates or do you mean the ammeter swings about when the engine is running ?
With the non working circuits you have so many that John's suggestion of the fuse box sounds like the best starting point to see firstly if you're getting a live feed to those circuits into and out of the fusebox.
After that, the biggest problem most of us seem to find with these cars is down to earthing. It's well worth making up a decent heavier duty wire for the earth circuits and  making sure every item has a good connection to it. You could even go fault finding with an earth lead to see if things light up !
Re: Electrics help
« Reply #6 on: Thursday,April 15, 2021, 02:12:13 PM »
90% of all electrical issues are ground problems... and that is on steel bodied cars!  Fibreglass is worse!  Anytime you get a I turn "this" on and "that" lights up, it's invariably a ground issue.
Offline Pete
Re: Electrics help
« Reply #7 on: Friday,April 16, 2021, 04:51:58 AM »
Thanks Brian. I have two workshop manuals for the Europa. Lol. And some for other lotus cars
Re: Electrics help
« Reply #8 on: Friday,April 16, 2021, 09:06:57 AM »
I've got one of those very early Elan manuals as well, it's interesting just how much detail Lotus expected their owners to have in those days. (probably because they didn't want to be bothered fixing the cars  ::)  )
