Author Topic: Ever wonder..., WHY?  (Read 1275 times)
Re: Ever wonder..., WHY?
« Reply #15 on: Thursday,June 17, 2021, 05:37:23 PM »
   The fight to return the harness back to a original is coming along . Here was a interesting repair made to the stop lights and reverse lights. I tried to follow the reasoning behind what was done.
 Pic 1 schematic tail lights area. Follow the GP legend .
  It terminates to the DB10 here no wire exist🥱
So what does a PO do. Wire a PW directly to the stop light switch. ( Install perfectly in the harness) Leaving the GW in harness. 👍
 Pic 2  two GB 👍, 1 R, 👍, 1GW,👍 , 1G 🥱 WTH, 🤯. So where does it end…reverse switch… 🤔
 I guess he settled on reverse and stop lights .
  With the rear section lights circuits separated from the engine compartment harness the engine harness looks pretty scarce mounted to its new location on the build board.
  I’ll add all the wiring as is for the rear lights for the length measurements with new wires.
« Reply #16 on: Sunday,June 20, 2021, 07:03:38 AM »
   With upgrading the coil from 8v -12v done by PO I found an interesting way to mark wires .
There is only one wht/blk in the harness but when omitting the ballast must have been confused on how to attach white wires to coil according to print.
