BDA , yep, 🤷🏼♂️😂. I started a bucket of show and tell items. 😂
Gavin,
Pic 1 , that ground wire is a loop! Not connected to under dash lug. completely installed thru the door rings, soldered, terminated . Only on one side .
Pic 2, switches not original according to the print ( 3 vs 6 terminals) and now you 👍 I only checked the ground strands, black wires and so far found 14 and 19 strands, I’ll be ordering wire soon.
Pic3, correct , I have dual lugs . I love the connection made from one side of that to the other.
Pic 4 /5 I’ll check the mfg . They did fit perfectly , however I will not be using them and I’ll have a relay mod installed instead.
There was also a ground wire route that I laughed about , rear side marker ground to interior light
It’s true!
