Author Topic: Three twin cam engines FS, Holbay $7k, others are less. NMNA  (Read 848 times)
« on: Friday,March 12, 2021, 08:43:53 AM »
I am buying the Kent 1600 pushrod engine for a Locost 7 build.
Maybe the TC's are of interest to some of you?
The Holbay TC should make for a lively ride in a Europa.
https://wichita.craigslist.org/pts/d/ar ... 54638.html
Not mine and my only interest is the Kent, maybe the 907 if I can find some additional funds.
Re: Three twin cam engines FS, Holbay $7k, others are less. NMNA
« Reply #1 on: Friday,March 12, 2021, 09:04:46 AM »
The link doesn't work for me.
« Reply #2 on: Friday,March 12, 2021, 09:38:51 AM »
Try this, https://wichita.craigslist.org/pts/d/arkansas-city-lotus-engines-and-parts/7274954638.html
This may be the answer to complete that Europa that is being sold less engine out of So. California.
Here is the text:
 I have been acquiring Twin Cam stuff for a while and I have too much. I have one complete, together Twin Cam and enough to build three more. This is a list of what I have:
Twin Cam, Weber Headed, Holbay motor, 701M casting "L" block, was a good running engine, been sitting for a couple years, would probably touch up the valves and give it a freshen. Complete with Weber DC40s and I have a header as well. $7000
120E block, needs bored to Lotus pistons, comes with almost new rotating assembly with six bolt crank, Stromberg head, cams, not sure which cams are in it, pan, Lotus cam cover, timing chain tensioner, water pump and backing plate. $3500
2731 Cortina GT block, needs bored to Twin Cam pistons, included, Stromberg head that needs a repair, Lotus cam cover, timing chain tensioner, water pump and backing plate covers, oil pan, have Lotus six bolt crank to go with it. $3000
78 Lotus 907 Euro Spec, out of a RHD Elite, with Lotus 5 speed, complete as it came out of the Elite, has the twin 45 DelOrtos. $1200
Also have 711M Crossflow engine, complete out of a Westfield 7, good running motor. $2500
Have other parts to include crossflow Weber intakes, headers, transmissions, etc.
I also have a rust free Cortina MK II with a cage in it already, no title, bill of sale only, has reinforced shock towers, motor mounts for Twin Cam.
I also have several sets of wheels for Cortinas.
I might also entertain selling my Mallock MK18BW race car, if you know what it is, and are looking for one, give me a shout...
« Last Edit: Friday,March 12, 2021, 09:40:38 AM by Richard48Y »
« Reply #3 on: Friday,March 12, 2021, 09:54:37 AM »
That works, thanks.
The Holbay engine is interesting. How does one access the spark plugs? Do the leads route through the hole at the back of the head? And, does the cam cover need removing to pull the plugs? Or am I just missing something?
« Reply #4 on: Friday,March 12, 2021, 10:24:08 AM »
I have no idea, the seller is Blake and you can get his phone number from the CL link.
Holbay certainly do make a clean looking engine.
Offline literarymadness
« Reply #5 on: Friday,March 12, 2021, 11:36:56 AM »
Here are a couple of photos of a Holbay installed in a Lotus 7.  I assume those are spark plug wires in the photos.
Offline MRN I J
    • Four Ashes Garage
« Reply #6 on: Friday,March 12, 2021, 11:45:30 AM »
the Holbay cam cover was for a dry sumped unit. no oil filler
Regards Chris
other cars inc wifes cars
« Reply #7 on: Friday,March 12, 2021, 11:48:35 AM »
It looks like there is a center panel that keeps water and dirt out from around the spark plugs.
Offline JR73
  • Banks Europa S2
« Reply #8 on: Friday,March 12, 2021, 11:53:31 AM »
It has a removable panel in the centre, spark plug access is the same as a standard TC once that cover is removed. You can just see the retaining bolts at either end in the centre.
« Reply #9 on: Friday,March 12, 2021, 01:19:53 PM »
Ah, I see it now. That makes sense. It would be a right pain, otherwise, especially on a performance engine. When I think of how many times I've pulled the plugs on my TC...
