Author Topic: Turbo Twin Cam  (Read 1179 times)
Offline surypap3
Turbo Twin Cam
« on: Wednesday,February 24, 2021, 01:35:42 PM »
TurboFource had mentioned a turbocharged TC. Does anyone know the details about that build?
Re: Turbo Twin Cam
« Reply #1 on: Wednesday,February 24, 2021, 03:08:00 PM »
There was an aftermarket offered back in the day.  I posted the brochure in this thread:
http://www.lotuseuropa.org/LotusForum/index.php?topic=4034.0
Re: Turbo Twin Cam
« Reply #2 on: Wednesday,February 24, 2021, 04:42:25 PM »
Working on mine.....it was not a kit....see link JB posted....hopefully it will be running this year ;)
Offline surypap3
Re: Turbo Twin Cam
« Reply #3 on: Thursday,February 25, 2021, 03:57:47 AM »
I like the novelty of it and I have a Europa that needs complete restoration. Thanks for the document. I'll read thru it. TurboFource, do you have in progress pictures of yours? Any design specs?
Offline surypap3
Re: Turbo Twin Cam
« Reply #4 on: Thursday,February 25, 2021, 04:06:51 AM »
After looking thru the document, this would hardly be worth doing to get to 150hp. If the design is brought up to date, what hp would you expect to make?
Re: Turbo Twin Cam
« Reply #5 on: Thursday,February 25, 2021, 07:51:37 AM »
It's not just the HP increase with forced induction. You get the same increase in torque. If you run 7.5 psi you are increasing the air pressure 50%. Not that you get get a full 50% increase in power but close.
Re: Turbo Twin Cam
« Reply #6 on: Thursday,February 25, 2021, 12:37:15 PM »
Sury,
JB posted a link to my build a couple of posts before this one. It was estimated my motor made around 200hp as it would build boost to over 10lbs (with spikes up to 14). There are pics of the system (I will be updating and simplifying things with a more modern turbo. I plan to leave it draw through carbureted in the spirit of the original build). I have owned several 4 cylinder turbo cars and you if haven't driven one all I can say is it really livens things up 8)
« Last Edit: Thursday,February 25, 2021, 12:41:21 PM by TurboFource »
Offline surypap3
Re: Turbo Twin Cam
« Reply #7 on: Thursday,February 25, 2021, 04:22:09 PM »
In your opinion, is trying to make a turbo Europa from the twin cam motor viable. Would need mods for fuel injection, airflow metering, manifold, electronic ignition and an ECU. Less worried about the exhaust side other than turbo placement. Thoughts? And would the outcome be worthwhile other than the novelty?
Re: Turbo Twin Cam
« Reply #8 on: Thursday,February 25, 2021, 04:45:02 PM »
Doing it old Skool like it was built in 1975 with a carb and just electronic ignition and water/methanol injection. Updating turbo and will probably use Snow Performance programmable water/methanol injection. Will probably add simple boost retard to ignition also.
A lot of turbo cars make more ft lbs of torque than hp.....
« Last Edit: Thursday,February 25, 2021, 04:46:43 PM by TurboFource »
Re: Turbo Twin Cam
« Reply #9 on: Monday,March 01, 2021, 03:53:05 PM »
The Checkpoint equipped Europa was supposed to outrun Ferraris.........
