Author Topic: rite way for thermosat  (Read 1232 times)
Offline mike alain
« on: Thursday,February 18, 2021, 05:15:45 AM »
Hi, just saw this pic of engine, is the thermostat wrong?  or did I put mine in backwards?  C   attached
Re: rite way for thermosat
« Reply #1 on: Thursday,February 18, 2021, 06:18:44 AM »
Fuzzy, small photo but that looks like the right way.  The brass container with the wax pellet goes towards the water pump.
« Reply #2 on: Thursday,February 18, 2021, 06:29:00 AM »
In this link, you can see the brass "bulb" goes into the water pump outlet:
https://www.renault16shop.com/7700573429?Lng=en#
Offline Sandyman
« Reply #3 on: Thursday,February 18, 2021, 09:20:58 AM »
Mike, the original thermostat has an air bleeder hole that is to be put at the top of the thermostat. This allows the block to be purged of air. Make sure that the one you install also has this hole. I drilled a small hole in the one I installed.
