Author Topic: 173 HP Twin Cam Motor for sale BAT  (Read 758 times)
Offline literarymadness
« on: Saturday,February 13, 2021, 02:05:10 AM »
Offline Dilkris
Re: 173 HP Twin Cam Motor for sale BAT
« Reply #1 on: Saturday,February 13, 2021, 06:54:10 AM »
Well - if it were this side of the pond - I would say an indecent amount of money, and that's before you start spending even more money changing all that required to be able to install it in a Europa.  :)
But, and, I know I am old, (and miserable), but what is it with those boy racer blue/red (aeroquip?) fittings...???  :help: I mean, that's like looking at a beautiful woman - and then seeing she has a beard, no?  :confused:
Offline Rosco5000
« Reply #2 on: Tuesday,February 16, 2021, 08:24:09 AM »
This is an interesting looking engine.  If you could verify its current state and hours that is one pricey build and you may get it for a steal.  Dry sump 9,000 rpm screamer!  Definitely suited to a 23 type car with light weight.  I have more than the current price ($4,400) into the bottom end of my Europa block and I already had the engine.
1974 Europa Special
1969 Europa S2
1970 Lotus Elan +2
  • ā€˜74 TCS - BDA - NG3
« Reply #3 on: Tuesday,February 16, 2021, 09:02:47 AM »
It is very nicely built. The crank isn't mentioned. It would be nice to know whether it is steel or cast iron.
I assume the 1500cc displacement is dictated by the class it's expected to run in.  For a race engine, 173hp @ 8500rpm is a little lower than I would expect. It has a pretty flay torque curve so you probably could drive it on the street!
I expect it to go for substantially more than the $4400 it's showing now. We'll see... I'm watching it.
« Reply #4 on: Friday,February 19, 2021, 03:15:47 PM »
Final bid $11,250!
« Reply #5 on: Friday,February 19, 2021, 03:33:16 PM »
That seemed a bit high to me but I’m far from an expert. It would have been a lot better to have compression and/or leak down numbers even if cold. Having said all that, given the apparent attention to detail, I would expect it was a quality build.
