Author Topic: Engine brackets positioning  (Read 1042 times)
Offline John R
« on: Tuesday,February 09, 2021, 05:55:00 AM »
Hi I'm just about to reinstall the rebuilt engine but I'm not sure if the brackets are in the right position as they don't seem to fit square on the engine - see photo
Greatly appreciate any advice
Thanks
John
Offline Dilkris
Re: Engine brackets positioning
« Reply #1 on: Tuesday,February 09, 2021, 08:54:11 AM »
Hi john R,
Please see below Forum discussion - read through it and it should answer your question
http://www.lotuseuropa.org/LotusForum/index.php?topic=4151.msg44416#msg44416
Where about in the UK are you?
Offline Dilkris
« Reply #2 on: Tuesday,February 09, 2021, 09:45:43 AM »
Hi John,
Was just looking at your rolling chassis - I may be wrong (it could be the camera angle), but you appear to have your anti roll bar and drop links mounted to the rear of your upper front wishbones - they should be on the front.
Offline John R
« Reply #3 on: Tuesday,February 09, 2021, 09:59:29 AM »
Interesting I'll check that
Thanks
Offline John R
« Reply #4 on: Tuesday,February 09, 2021, 12:16:35 PM »
You're perfectly right - don't know how  did that!
Many thanks
