Author Topic: New Renault Cross flow engine is finished. HP and Tprque chart  (Read 532 times)
Offline gl6
« on: Monday,February 01, 2021, 11:56:49 AM »
Hi Europa fans.  My 'Covid Project' was to work through the details for a proper racing Renault Cross flow Engine.
(See images attached)
154HP @ 6100 RPM and 145 Ft/LB torque at 4800 RPM.
For the final assembly I had Arnie Loyning  complete the work and dyno tune.
Arnie at Loyning's engine service in Portland OR has a lot of experience with Renault.
Re: New Renault Cross flow engine is finished. HP and Tprque chart
« Reply #1 on: Monday,February 01, 2021, 12:05:09 PM »
Pretty cool! It's good that Loyning knows Renault motors too. I remember his name from when I was racing an age ago. IIRC, he was a big name in Formula Ford motors. It looks like he did a nice job for you.
« Reply #2 on: Monday,February 01, 2021, 12:34:14 PM »
Nice!
Offline literarymadness
« Reply #3 on: Monday,February 01, 2021, 03:16:02 PM »
 :beerchug: Someone is going to be having a lot of fun. Congrats!
« Reply #4 on: Monday,February 01, 2021, 07:31:25 PM »
Hard to tell from a picture but make sure your carb mounts are not too tight.
154 hp sounds good!  Care to share what was done to it?
Offline gl6
« Reply #5 on: Tuesday,February 02, 2021, 11:18:19 AM »
Sure:
Start by reading Richard Mann's fabulous posts regarding the 807 Renault engine.
Pistons and liners from Meca parts in France (domed pistons to increase compression)  BTW, you will need to pocket the pistons for the larger valves.  And you will need to bore the block for the larger diameter of the liners.
http://www.mecaparts.com/Moteurs/page.php?lang=0&sortie=html&col=A110&page=1#ok
Use the longer stroke Renault crank (again read Richard Mann's post = 84mm crank)
Porting the head intake and exhaust by Loyning.  And installation of bigger valves.  Valves from Meca.  http://www.mecaparts.com/Moteurs/page.php?lang=0&sortie=html&col=A110&page=1#ok, http://www.mecaparts.com/Moteurs/page.php?lang=0&sortie=html&col=A110&page=1#ok
Loyning has their own cam grind - I'll find and post the specs.  There isn't a huge increase on the lift - because the rocker arms in these engines are very long, the duration is much bigger than a stock engine.
Regarding the carbs:  On the Dyno we tried Weber DCOE 45 and DCOE 40.  The 40s are better.  Particularly to move the torque peak down to a lower RPM.  When racing and exiting a turn you will want that torque.
The Webers are mounted on soft mounts to decrease vibration.  You can get the soft mounts from carbs unlimited  https://www.carburetion.com/Weber/WeberDCOEParts.asp
More to come.
« Last Edit: Tuesday,February 02, 2021, 11:36:16 AM by gl6 »
Online RonPNW
  • S2 54/1678
« Reply #6 on: Tuesday,February 02, 2021, 02:01:50 PM »
Very nice.
How long did it take to rebuild the engine?
Ron
« Reply #7 on: Tuesday,February 02, 2021, 02:31:43 PM »
What bore liners are you running?
Offline gl6
« Reply #8 on: Wednesday,February 03, 2021, 10:59:47 AM »
The liner is MECA part number MP0423
Offline gl6
« Reply #9 on: Wednesday,February 03, 2021, 11:01:30 AM »
Ron,
I started the project last March.  Three months of that time everything was shut down.
Greg
