Author Topic: Silencer removal  (Read 330 times)
Offline Sparkrite
Silencer removal
« on: Saturday,January 30, 2021, 09:34:37 AM »
It seems like too dumb a question to ask but I cant see a way of removing the silencer box on my tc. The only possible solution may be to remove a drive shaft, but that surely cant be right.
Re: Silencer removal
« Reply #1 on: Saturday,January 30, 2021, 09:46:02 AM »
The easy way is to remove the luggage tray so you can stand in the engine bay, it gives better access.
There's no need to touch the driveshaft, it just needs the connection to the 90deg section loosening and then a contribution to the swear box as you wrestle it out. I'd spray it with WD40 once the silencer/tube connection is undone and let it soak for a bit.  That's assuming a stainless system, if you're on mild steel then I'd just take a cutting disc to it !
Offline Sparkrite
« Reply #2 on: Saturday,January 30, 2021, 11:52:58 AM »
Thanks Brian. Ive already got all the connections off so fingers crossed it should come out okay.
