Author Topic: No beads in tubing?  (Read 535 times)
No beads in tubing?
« on: Monday,January 25, 2021, 01:38:29 PM »
I was just curious why none of the tubing I have taken apart so far on the Europa has a bead formed into it
to prevent the hose etc. from coming off? It does make disassembly easier...... ::) but the point of having them
is to prevent the hose from coming off easily....
Re: No beads in tubing?
« Reply #1 on: Monday,January 25, 2021, 01:53:15 PM »
The tubes I'm thinking of are the transfer tubes and the heater tubes. Are there others?
The transfer tubes fit pretty snugly in the grommets in the frame so having a bead would make assembling that much harder.
I don't know why the heater tubes weren't beaded.
« Reply #2 on: Monday,January 25, 2021, 03:08:00 PM »
BDA is right, if you bead the main coolant tube ends, you can't get them through the grommets.  I just put a three or four rivets at the end of each tube after installing.  Works the same as a beaded end but you can drill them out if you have to remove the tubes.  All the other tubes I made up myself and beaded their ends.
« Reply #3 on: Monday,January 25, 2021, 10:10:09 PM »
How did you form the beads, JB?
There are a few rather spendy gadgets around but I'd like to avoid those considering the small number of beads needed.
There's also the range of sizes to consider - 1/2 inch for the heater tubes and 1-1/4 inch for the coolant tubes.
Offline Dilkris
« Reply #4 on: Tuesday,January 26, 2021, 01:59:47 AM »
That's clever John - where did you learn that from?
« Reply #5 on: Tuesday,January 26, 2021, 06:38:57 AM »
I had the beading tools already from when I worked.  They are expensive so look for a shop that has them.  An aircraft, race-prep, or good restoration shop should have them.
It is clever.  Not my idea though.  Read it somewhere.
« Reply #6 on: Tuesday,January 26, 2021, 12:21:02 PM »
I agree, it's clever and simple!
